  • Red Glue SMT Solutions: A Cost-Effective Approach for Double-Sided PCBs
Mar 27, 2024
Revolutionizing Double-Sided PCB Assembly with Red Glue SMT
The world of PCB assembly is constantly evolving, and Red Glue SMT Solutions offer a revolutionary approach for double-sided printed circuit board assemblies (PCBAs). This innovative technique overcomes limitations of traditional solder paste and reflow ovens, paving the way for increased efficiency and cost savings.
Addressing Double-Sided PCB Challenges
Traditional SMT assembly often struggles with double-sided PCBAs due to the differing requirements of SMD (Surface Mount Devices) and through-hole components. Red Glue SMT solves this by:
  • Eliminating high reflow temperatures unsuitable for delicate SMDs.
  • Offering a versatile solution that accommodates both SMD and through-hole components.
SMT Production Line In Red Glue SMT Solution:
SMT Loader
PCB Printing Machine
SMT Conveyor
SMT Pick and Place Machine
PCB Conveyor
PCB Cooling Conveyor
SMT Flipper
DIP Production Line In Red Glue SMT Solution:
Radial Insertion Machine
Axial Insertion Machine
Odd Form Component Insertion Machine
PCB Elevator
Wave Loader
Wave Solder Machine
Wave Unloader
SMT AOI machine
PCB NG/OK Unloader
The Red Glue SMT Process
Red Glue SMT utilizes a unique process specifically designed for double-sided PCBAs. Here's a breakdown of the key steps:
Applying Red Glue
  • SMT Stencil Printer: Unlike conventional printers, this specialized unit applies Red Glue precisely between components, adhering them to the PCB. The stencil is specifically designed for Red Glue and differs from the standard solder paste steel mesh.
Standard SMT Processes
  • Pick and Place Machine: As with conventional SMT assembly, components are accurately positioned onto the PCB.
Curing Red Glue
  • Reflow Soldering Oven/IR Curing Furnace: Due to the lower curing temperature of Red Glue (around 100-120°C), extremely high reflow temperatures are no longer necessary. In some cases, an even more cost-effective IR curing furnace is used.
Flipping and Populating the Other Side
  • Flipper: The PCB is flipped to ensure SMD components face downwards.
  • Insertion Machines: Three separate machines handle radial, axial, and odd-form through-hole components, placing them precisely.
Budget-Friendly Option: A manual 9-meter insertion line is available for cost-conscious clients.
Completing the Assembly
  • Wave Soldering: The high-temperature solder wave simultaneously reaches contact points of both SMD and through-hole components for efficient soldering.
  • AOI (Automated Optical Inspection): The AOI system inspects both SMT and DIP (Through-Hole) components for comprehensive quality control.
Advantages of Red Glue SMT Solutions
  • Cost-Effectiveness: Red Glue SMT eliminates the need for high-temperature solder paste and reflow ovens, leading to significant energy cost savings.
  • Versatility: This method caters to double-sided PCBAs with both SMD and through-hole components, providing a one-stop solution.
  • Lower Thermal Stress: The lower curing temperature of Red Glue minimizes thermal stress on components, potentially improving long-term reliability.
Partnering for Your Red Glue SMT Needs
Our dedicated engineering team is here to provide customized Red Glue SMT solutions that precisely meet your specific requirements. All our equipment adheres to European safety standards and holds CE certification. We are committed to delivering exceptional service, maintenance support, and helping you transform your ideas into reality. Contact our engineers today for a consultation tailored to your specific SMT needs.
Aug 20, 2024 -
Aug 17, 2024 -
Selective Wave Soldering for High-Reliability Electronics
Aug 09, 2024 -
Jul 26, 2024 -
Jul 16, 2024 -
May 30, 2024 -
May 15, 2024 -
I.C.T Supporting EMS Manufacturers for Indonesian customers
May 13, 2024 -
I.C.T Global Technical Support for Customized SMT Reflow Oven in Malaysia
Apr 29, 2024 -
SMT AOI Machine: Revolutionizing SMT Inspection with AI Technology
Apr 23, 2024 -
New Energy Automotive: I.C.T.'s Conformal Coating Line Expertise in Mexico
91 more news from I.C.T ( Dongguan ICT Technology Co., Ltd. ) »
Sep 13, 2024 -
RELIANCE 57C405-E
Sep 13, 2024 -
HMS ABC-PDP AB7000-B
Sep 13, 2024 -
Sep 13, 2024 -
Sep 13, 2024 -
YOKOGAWA S9400UK
Sep 13, 2024 -
Sep 13, 2024 -
Sep 13, 2024 -
ABB DTDX707A 61430001-WG
Sep 13, 2024 -
GE IC220STR001
Sep 13, 2024 -
Red Glue SMT Solutions: A Cost-Effective Approach for Double-Sided PCBs news release has been viewed 270 times
Manufacturing Software
