  • Pickering Interfaces Showcases New Switching Modules and Chassis at productronica 2013 in Munich
Oct 24, 2013
Products Include LXI, PXI, Digital I/O, Microwave Multiplexer and PCI Ranges.
Pickering Interfaces, a leading provider of signal switching and conditioning solutions, will be showcasing it’s newest switching modules and chassis at productronica 2013. These products include PXI RF Solid State 6 GHz Multiplexers, 3U 16Amp PXI Switching Modules, 5Amp PXI Power Multiplexer Module, 32-Channel PCI Digital I/O Card, an upgrade to its popular LXI Modular Chassis and an upgrade to one of their PXI Microwave Multiplexers.
Test Engineers need choices in order to balance their budget with the specified testing requirements,” states Keith Moore, Managing Director at Pickering Interfaces. “With our continually growing range of switching products, our philosophy at Pickering will always be to offer the right amount of switching, with the required performance, at the right cost no matter what the application may be.”
The new PXI RF Solid State 6 GHz Multiplexers (40-883) include an SP8T (8:1) MUX occupying two PXI slots and an SP16T (16:1) MUX occupying three PXI slots. Each MUX uses solid-state switches that ensure fast switch operation time of 50µs, very repeatable performance and an indefinite service life when used within ratings. The designs have been carefully optimized for VSWR performance and insertion loss. Particular attention has been paid to crosstalk and isolation to ensure that unselected switch paths have minimal output signal content. Each multiplexer can handle up to +30dBm of signal power and signal frequencies from 10MHz to above 6GHz. Unused ports are automatically terminated to manage VSWR effects in cables.
These new versions compliment our 6GHz PXI solid state switch family that already includes SPDT, SP4T MUXs and a 4x4 matrix solution,” states David Owen, Business Development Manager for Pickering Interfaces. “Solid state RF switches are an ideal solution where test systems need fast test times, repeatability and long service life."
The new 3U 16Amp PXI Switching Module (40-161) is capable of switching currents up to 16A and voltages up to 300VDC/250VAC with hot switch power of 480W at 30VDC and 4000VA at 250VAC. The new switching module is available with configurations of 16, 12, or 10 SPST, or 12 or 6 SPDT relays.
16A switching has been minimally supported by the PXI industry to date,” said Shaun Fuller, Pickering’s Switching Product Manager. “With the increase of new functionality in areas like the Automotive Industry, and increasing requirements for automation in Defense and Aerospace, the need for PXI to support higher current applications has become very clear. This switching module is part of our effort to fill that gap.”
The module occupies one slot of a 3U PXI chassis and user signals are carried on one or two GMCT 24 way connectors fitted with 16A contacts.
The new 5Amp Power Multiplexer Module (40-651) is a high density multiplexer (MUX) capable of hot switching up to 5A and 110VDC/250VAC; and the hot switch power is up to 150W or 1250VAC.
The Power MUX is available in a variety of configurations to suit different applications. Configurations are a single 48:1 MUX, a dual 24:1 MUX, a quad 11:1 MUX and an octal 5:1 MUX. The single and dual MUX models include an isolation relay in the common to reduce the cable load when the MUX is not in use. All models use robust electro-mechanical relays on silver alloy contact materials and include a spare relay to facilitate relay replacement.
The PXI Microwave Multiplexer Upgrade (40-784A) supports one, two, or three microwave multiplexers and the multiplexers can be ordered as either 4 or 6-way. The multiplexers fitted to each model are characterized for bandwidths of 6, 18, 26.5, or 40 GHz and have excellent performance throughout their frequency range. All models occupy just two 3U PXI slots. The single and dual multiplexers all feature LED’s that indicate which path of the multiplexer is closed.
All the PXI modules can be used in any PXI chassis, can be fitted to PXI hybrid slots in a PXIe chassis and can also be used in Pickering’s LXI Modular chassis for users preferring control via an Ethernet port.
The LXI Modular Chassis Upgrade (60-102B and 60-103B) increases the Ethernet interface speed to 1Gb from 100Mb, as well as adding an IP display that shows the IP address of the chassis. The LXI Modular Chassis provides an easy way of supporting Pickering Interfaces 3U PXI modules in an Ethernet-based LXI control environment. All Pickering’s PXI switching products are supported along with simulators such as resistor modules and battery emulators; the majority of Pickering’s PXI instruments and power supply products are also supported. The 60-102B allows up to seven PXI modules while the 60-103B allows up to 18 PXI modules.
There is very little difference in speed or overall latency between PXI and LXI switching implementations, performance is largely determined by the switching components,” states David Owen. “We firmly believe that some users can benefit from controlling switching systems from an Ethernet port since it makes control at a distance easier and provides a familiar web experience of the products supported.”
The new PCI 32-Channel Digital I/O Card (50-412) is capable of driving high current loads and reading back the logical state of high voltage logic signals. The card provides 32 channels of digital output lines that can serve as high or low side drivers. Each channel is capable of sourcing 0.4A or sinking 0.5A at voltages up to 50V and has protection circuits that prevent over voltage, over current or thermal overload from occurring. Software allows each channel to be independently selected for high or low side driving  while interlocks prevent the high and low side drivers on a channel from being operated at the same time.
This digital I/O card also provides dual variable logic threshold that permits users to detect when an input is in a low state, an intermediate state or a high state from a single read operation. The high input impedance ensures minimal loading on the digital inputs. A single command allows the user to sequentially capture the status of all 32 input channels
For applications requiring the read back of an output driver state, users of the 50-412 can connect the digital input and digital outputs together in a cable assembly or connector block.
PCI remains an attractive test platform for many test system designers, particularly those with cost sensitive low to moderate complexity applications,” according to David Owen, “ The availability of high and low side drivers and digital inputs in a single module is ideal for applications where a common test platform is required to test a variety of UUT’s.
All of these new and upgraded switching modules and chassis will be showcased at productronica 2013 in Hall A1 – Booth 452, 12 – 15 November at the Munich Trade Fair Centre in Munich German. For more information on productronica 2013, go to www.productronica.com.
Pickering Interfaces stands behind their products with a standard three-year warranty on all products. Pricing and availability information is supplied on their web site at www.pickeringtest.com.
Pickering Interfaces offers signal switching and conditioning for a broad range of applications and architectures. Today, Pickering’s portfolio contains the largest range of switching cards in the industry for PXI, LXI, PCI, VXI and GPIB applications. Pickering’s products are specified in both commercial and military test systems installed throughout the world and have a reputation for providing excellent reliability and value. Pickering operates globally with direct operations in the US, UK, Germany, Sweden, France, Czech Republic, and engineering support in China, together with additional representation in countries throughout the Americas, Europe and Asia. Pickering serves a wide variety of markets, including automotive, aerospace & defense, power generation, energy and commercial electronics industries. For additional information, visit www.pickeringtest.com.
May 20, 2018 -
May 07, 2018 -
May 03, 2018 -
Apr 27, 2018 -
Apr 24, 2018 -
Mar 12, 2018 -
Mar 11, 2018 -
Oct 30, 2017 -
Oct 17, 2017 -
Oct 15, 2017 -
Jul 16, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
