  • Pickering Interfaces to Showcase Latest Switching Modules and Chassis at Southern Manufacturing & Electronics Exhibition in Farnborough, UK
Jan 21, 2014
PXI RF Solid State 6 GHz Multiplexers (40-88X).
PXI Microwave Multiplexer Upgrade (40-784A) supports one, two, or three microwave multiplexers and the multiplexers can be ordered as either 4 or 6-way.
Pickering Interfaces, a leading provider of signal switching and conditioning solutions, will be showcasing its latest switching modules and chassis at the Southern Manufacturing & Electronics Exhibition on 12 – 13, February 2014 in Stand J66. These products include Pickering's LXI, PXI, Digital I/O, Microwave Multiplexer and PCI Ranges.
PXI RF Solid State 6 GHz Multiplexers (40-88X) - includes an SP8T (8:1) MUX occupying two PXI slots and an SP16T (16:1) MUX occupying three PXI slots. Each MUX uses solid-state switches that ensure fast switch operation time of 50µs, very repeatable performance and an indefinite service life when used within ratings. The designs have been carefully optimized for VSWR performance and insertion loss. Particular attention has been paid to crosstalk and isolation to ensure that unselected switch paths have minimal output signal content. Each multiplexer can handle up to +30dBm of signal power and signal frequencies from 10MHz to above 6GHz. Unused ports are automatically terminated to manage VSWR effects in cables.
3U 16Amp PXI Switching Module (40-161) is capable of switching currents up to 16A and voltages up to 300VDC/250VAC with hot switch power of 480W at 30VDC and 4000VA at 250VAC. The new switching module is available with configurations of 16, 12, or 10 SPST, or 12 or 6 SPDT relays. The module occupies one slot of a 3U PXI chassis and user signals are carried on one or two GMCT 24 way connectors fitted with 16A contacts.
5Amp Power Multiplexer Module (40-651) is a high density multiplexer (MUX) capable of hot switching up to 5A and 110VDC/250VAC; with hot switch power up to 150W or 1250VA.
The Power MUX is available in a variety of configurations to suit different applications. Configurations are a single 48:1 MUX, a dual 24:1 MUX, a quad 11:1 MUX and an octal 5:1 MUX. The single and dual MUX models include an isolation relay in the common to reduce the cable load when the MUX is not in use. All models use robust electro-mechanical relays on silver alloy contact materials and include a spare relay to facilitate relay replacement.
PXI Microwave Multiplexer Upgrade (40-784A) supports one, two, or three microwave multiplexers and the multiplexers can be ordered as either 4 or 6-way. The multiplexers fitted to each model are characterized for bandwidths of 6, 18, 26.5, or 40 GHz and have excellent performance throughout their frequency range. All models occupy just two 3U PXI slots and feature LED’s that indicate which path of the multiplexer is closed.
All the PXI modules can be used in any PXI chassis, can be fitted to PXI hybrid slots in a PXIe chassis and can also be used in Pickering’s LXI Modular chassis for users preferring control via an Ethernet port.
LXI Modular Chassis Upgrade (60-102B and 60-103B) increases the Ethernet interface speed to 1Gb from 100Mb, as well as adding an IP display that shows the IP address of the chassis. The LXI Modular Chassis provides an easy way of supporting Pickering Interfaces 3U PXI modules in an Ethernet-based LXI control environment. All Pickering’s PXI switching products are supported along with simulators such as resistor modules and battery emulators; the majority of Pickering’s PXI instruments and power supply products are also supported. The 60-102B allows up to seven PXI modules while the 60-103B allows up to 18 PXI modules.
PCI 32-Channel Digital I/O Card (50-412) is capable of driving high current loads and reading back the logical state of high voltage logic signals. The card provides 32 channels of digital output lines that can serve as high or low side drivers. Each channel is capable of sourcing 0.4A or sinking 0.5A at voltages up to 50V and has protection circuits that prevent over voltage, over current or thermal overload from occurring.
Pickering Interfaces stands behind all of their manufactured products with a standard three-year warranty. Pricing and availability information is supplied on their web site at www.pickeringtest.com.
Pickering Interfaces offers signal switching and conditioning for a broad range of applications and architectures. Today, Pickering’s portfolio contains the largest range of switching cards in the industry for PXI, LXI, PCI, VXI and GPIB applications. Pickering’s products are specified in both commercial and military test systems installed throughout the world and have a reputation for providing excellent reliability and value. Pickering operates globally with direct operations in the US, UK, Germany, Sweden, France, Czech Republic, and engineering support in China, together with additional representation in countries throughout the Americas, Europe and Asia. Pickering serves a wide variety of markets, including automotive, aerospace & defense, power generation, energy and commercial electronics industries. For additional information, visit www.pickeringtest.com. Also visit us on Twitter, LinkedIn, and Facebook.
May 20, 2018 -
May 07, 2018 -
May 03, 2018 -
Apr 27, 2018 -
Apr 24, 2018 -
Mar 12, 2018 -
Mar 11, 2018 -
Oct 30, 2017 -
Oct 17, 2017 -
Oct 15, 2017 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Pickering Interfaces to Showcase Latest Switching Modules and Chassis at Southern Manufacturing & Electronics Exhibition in Farnborough, UK news release has been viewed 937 times
