  • Pickering to Show Latest Switching Modules at AMPER 2015 in Brno, Czech Republic
Mar 10, 2015
Pickering Interfaces, a leading provider of signal switching and conditioning solutions will be showcasing their broad catalog of PXI and Ethernet LXI switching solutions at Amper, in Hall V, Booth 3.18 on March 24-27. These products include Pickering’s LXI, PXI, Programmable Resistors, Microwave Multiplexer and PCI Ranges. Below is a preview of some of the products they will be showing:
PXI Microwave Multiplexer (40-784A) - these support single, dual, or triple SP4T or SP6T relays and are available in a variety of different frequency options for 50 Ω, from 6GHz to 40GHz. All models occupy just two 3U PXI slots and feature LED’s that indicate which path of the multiplexer is closed.
PXI and PCI Programmable Resistor Solutions. Pickering Interfaces offers the widest range of programmable resistor modules in PXI and PCI format. Many of these models cover applications that require low cost solutions through to those that require high precision and the best stability achievable.
PXI High-speed USB Switching Systems - including a USB Hub that can be used to connect USB devices under test or USB test equipment directly into PXI systems.
BRIC™ PXI Large Matrix Modules, the use of high-density packaging and integrated backplanes enables a large matrix to be implemented with no user configuration or special matrix expansion kits. These matrices use thru-hole mechanical relays (not surface mount) and can be serviced using standard de-soldering tools simplifying repair and reducing down time. The BRIC's integrated design ensures high matrix performance with high signal bandwidth and fewer system implementation errors.
LXI Switching (Ethernet controlled) Systems - LXI systems support large switching systems with simplified control through an Ethernet connection. LXI is the power of Ethernet and the Web applied to Test & Measurement (T&M) instruments, offering you new possibilities in test systems – local, remote, distributed and time-aware.
Switching System Management Tools - these tools reduce the cost of ownership of switching systems in all commonly used platforms.
All the PXI modules can be used in any PXI chassis, can be fitted to PXI hybrid slots in a PXIe chassis and can also be used in Pickering’s LXI Modular chassis for users preferring control via an Ethernet port.
Pickering Interfaces also has a Czech-based manufacturing facility that produces their cables and connectors designed to work with their switching systems. Pickering will be previewing their new Cable Configurator Tool in the booth, this tool aids users in the specifying of custom cables.
May 20, 2018 -
May 07, 2018 -
May 03, 2018 -
Apr 27, 2018 -
Apr 24, 2018 -
Mar 12, 2018 -
Mar 11, 2018 -
Oct 30, 2017 -
Oct 17, 2017 -
Oct 15, 2017 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
Pickering to Show Latest Switching Modules at AMPER 2015 in Brno, Czech Republic news release has been viewed 876 times
