  • Pickering Interfaces Expands PXI Fault Insertion Switch Range for Differential Serial Interfaces
Sep 19, 2015
Pickering Interfaces, a leading supplier of modular signal switching for electronic test and simulation, is expanding its range of PXI Fault Insertion switching with the introduction of two new modules (models 40-200 and 40-201) designed for use with differential serial interfaces.
Shaun Fuller, Pickering’s Switching Product Manager, explained “Serial interfaces are extensively used for communication between sub-assemblies in electronic systems, including applications where personal safety issues arise such as in automotive applications. These applications require manufacturers to test for the system response to communication failures or other interruptions/failures to ensure the system responds in a safe way. These new PXI Fault Insertion modules give manufacturers the ability to simulate faults on commonly used differential serial interfaces.
The new modules include the Differential PXI Fault Insertion Switch (model 40-200) which is designed for lower data rate serial interfaces such as CAN and FlexRay, and the High Bandwidth Differential PXI Fault Insertion Switch (model 40-201) which is designed for higher data rate serial interfaces such as AFDX and 1000BaseT Ethernet. Each module allows the introduction of fault connections that include data paths open, data paths shorted together, and data paths shorted to externally applied faults such as power supplies and ground. The software driver defaults to a protective mode where conflicting faults are prevented to avoid accidentally shorting unintended paths, such as power to ground. A separate mode allows complete freedom in setting fault patterns.
These PXI fault insertion modules will find application in testing the response of safety-critical communication systems used in automotive and aerospace environments. Each module is available with a choice of channel counts, allowing users to choose the most appropriate solution for the intended application.
Both modules are supported by Pickering’s new eBIRST switching system test tool. These tools simplify switching system fault-finding by quickly testing the system and identifying the faulty relays. Once identified, the tools then display a graphical representation of the switching system’s PCB assembly, highlighting the relays that need to be replaced.
Connections are available on an easy to use 78-way D connector and are supported by Pickering’s range of general purpose (non-differential) cable and connector options. In addition, Pickering Interfaces can design and supply differential interface adaptors to application specific connectors.
Pickering Interfaces stands behind all of their manufactured products with a standard three-year warranty and guaranteed long-term product support. Pricing and availability information is supplied on their website at www.pickeringtest.com.
Pickering Interfaces designs and manufactures modular signal switching and instrumentation for use in electronic test and simulation. We offer the largest range of switching cards in the industry for PXI, LXI, PCI and GPIB applications as well as a full range of supporting cables and connectors. Pickering’s products are specified in test systems installed throughout the world and have a reputation for providing excellent reliability and value. Pickering Interfaces operates globally with direct operations in the US, UK, Germany, Sweden, France, Czech Republic and China, together with additional representation in countries throughout the Americas, Europe and Asia. We currently serve the automotive, aerospace & defense, power generation, energy and commercial electronics industries. For more information on signal switching and conditioning products or sales contacts please visit www.pickeringtest.com.
May 20, 2018 -
May 07, 2018 -
May 03, 2018 -
Apr 27, 2018 -
Apr 24, 2018 -
Mar 12, 2018 -
Mar 11, 2018 -
Oct 30, 2017 -
Oct 17, 2017 -
Oct 15, 2017 -
Jul 02, 2024 -
Totech Canada N/A Inc celebrates 5 Year as Official Distributor for TOTECH GLOBAL North America
Jul 01, 2024 -
XDry Dry Cabinets Hires Wilson Industries as Representative for New York
Jul 01, 2024 -
EVS International Welcomes Circuit Assembly Products SE as New Representative for Southern States
Jul 01, 2024 -
Prey by Detech Partners with Accurex Solutions to Expand Presence in India
Jul 01, 2024 -
PEMTRON to Showcase Advanced Inspection Systems at ASPS in Korea
Jul 01, 2024 -
iNEMI Announces Member Recognition Awards for 2024
Jul 01, 2024 -
IPC White Paper Emphasizes the Critical Importance of 'Design for Excellence' Throughout the Full Ecosystem of Electronics Design
Jul 01, 2024 -
ZESTRON Welcomes Daniel Chacon to the LATAM Sales Team
Jul 01, 2024 -
TAGARNO Welcomes Mark Sullivan as New Sales Representative for the American Market
Jul 01, 2024 -
ViTrox Americas Opens New State-of-the-Art Demo Lab in Hutto, Texas
Pickering Interfaces Expands PXI Fault Insertion Switch Range for Differential Serial Interfaces news release has been viewed 925 times
