  • Pickering to highlight High Voltage Relays with unusual package design at Semicon West
Jul 11, 2016
Pickering Electronics are worldwide manufacturers and distributors of high quality Reed Relays for ATE, Low thermal EMF, RF switching and other specialist applications, available in Surface Mount, Single-in-Line (SIL), Dual-in-Line (DIL) and many other popular package styles.
Pickering’s newly released Series 67 and 68 Reed Relay range present some interesting packing possibilities for high density applications such as multiplexers and matrices in instrumentation and test systems (see dimensions in related image).
These diverse Reed Relays are available for up to 10kV stand-off, 7.5kV switching, with an option of either PCB or flying lead switch connections. Similar in specification to the long established Pickering Series 60/65, these new relays are manufactured in a Single-in-Line (SIL/SIP) format using former-less coils which dispense with the more usual coil supporting bobbin, allowing a smaller package than similar rated devices.
5, 12 and 24 volt coils are available as standard, and other voltages can be supplied to special order, as can variations in the lead length of the Series 68 range. The relays are suitable for high voltage transformer and cable test and some electro-medical applications such as defibrillators.
Learn more about Pickering and their high quality Reed Relay ranges by visiting stand 5877 at Semicon West this July, or alternatively go to: www.pickeringrelay.com.
Pickering Electronics will co-exhibit with their sister company; Pickering Interfaces. Pickering Interfaces designs and manufactures modular signal switching and simulation for use in electronic test. Discover more at: www.pickeringtest.com.
May 20, 2018 -
May 07, 2018 -
May 03, 2018 -
Apr 27, 2018 -
Apr 24, 2018 -
Mar 12, 2018 -
Mar 11, 2018 -
Oct 30, 2017 -
Oct 17, 2017 -
Oct 15, 2017 -
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Pickering to highlight High Voltage Relays with unusual package design at Semicon West news release has been viewed 1111 times
