  • Nordson MARCH MesoSPHERE Plasma Systems Enable Very High Throughput Processing for 3D and Wafer-level Package Assembly
Feb 01, 2018
For substrates up to 480mm during semiconductor packaging
Nordson MARCH, a Nordson company (NASDAQ: NDSN), a global leader in plasma processing technology, introduces the MesoSPHERE™ Plasma System for very-high throughput processing of 3D and wafer-level packaging processes such as fan-in, fan-out, wafer-level, and panel-level -handling wafers up to 450mm and panels up to 480mm. The MesoSPHERE's new, patented W3 three-axis symmetrical plasma chamber ensures that all areas of the wafer are treated equally and uniformly. Tight control over all process parameters gives highly repeatable results.
For wafer cleaning, the MesoSPHERE plasma system removes contamination prior to wafer bumping, organic contamination, fluorine and other halogen contamination, and metal and metal oxides. Plasma improves spun-on film adhesion and cleans metallic bond pads.
For wafer etching, the MesoSPHERE plasma system descums wafers of residual photoresist and BCB, pattern dielectric layers for redistribution, strip/etch photoresist, enhances adhesion of wafer applied materials, removes excess wafer applied mold /epoxy, enhances adhesion of gold solder bumps, destresses wafer to reduce breakage, improves spun-on film adhesion, and cleans aluminum bond pads.
The MesoSPHERE's chamber design and control architecture enable short plasma cycle times with very low overhead, maximizing throughput and minimizing cost of ownership. Plasma confinement technology uses a ring to isolate and focus plasma so it's distributed directly above the wafer, minimizing undesired secondary reactions. Process temperatures can be kept low because the ring increases etch rate capability without increasing the electrode temperature or adding bias to the chuck.
An innovative handling system transfers round or square substrates and frame or bonded carriers. The modular design allows capacity increase on a per plasma chamber basis. Equipment front end module (EFEM) integration supports from 1 to 4 plasma chambers. A pocket chuck design provides accurate substrate placement and centering, for additional process repeatability.
"A unique feature of the MesoSPHERE is the way we developed the isolation," explained Jonathan Doan, director of marketing for Nordson MARCH. "It allows our customers a method to perform advanced packaging without having to use an expensive carrier and it can be used with 300mm wafers on frames."
Nordson MARCH designs and manufactures a complete line of award-winning and patented plasma treatment systems that improve product reliability and increase production yields. Delivering over 30 years of continuous innovation Nordson MARCH is a global leader in plasma processing technology for manufacturing semiconductors, printed circuit boards, microelectronics, and medical devices with offices and labs worldwide, including the USA, Europe, Singapore, China, Japan, and Korea. An expert staff of scientists and engineers is available to assist development of plasma processes. Visit Nordson MARCH at www.nordsonmarch.com, Facebook or Twitter.
Nordson Corporation engineers, manufactures and markets differentiated products and systems that dispense, apply and control adhesives, coatings, polymers, sealants, biomaterials, and other fluids, test and inspect for quality, and treat and cure surfaces, and are supported by application expertise and direct global sales and service. Nordson serves many consumer non-durable, durable and technology end-markets including packaging, nonwovens, electronics, medical, appliances, energy, transportation, construction, and general product assembly and finishing. Founded in 1954, headquartered in Westlake, Ohio, Nordson has operations and support offices in nearly 40 countries. Visit Nordson at www.nordson.com, Twitter or Facebook.
Jan 15, 2020 -
Nordson MARCH Introduces Plasma Treatment System with 2-Meter Depth for Improved Manufacturing of Extended Catheters and Larger Products
Apr 01, 2019 -
Nordson MARCH FlexTRAK-SHS High-capacity Plasma Treatment System Provides Enhanced Automation and Production Flexibility
May 31, 2018 -
Nordson MARCH Receives Vision and Innovation Awards at NEPCON China for its RollVIA Self-contained Vacuum Plasma System
Mar 07, 2018 -
Nordson MARCH Receives NPI Award for its RollVIA Self-contained Vacuum Plasma System
Nov 29, 2017 -
Nordson MARCH Introduces the new-generation RollVIA plasma system for roll-to-roll production in PCB manufacturing operations Completely Self-Contained with Integrated Pump Package
Nov 08, 2017 -
Nordson MARCH Will be Ready to Discuss Plasma Technologies at Productronica 2017
Oct 05, 2017 -
Nordson MARCH Presents Paper at SMTA Guadalajara on Enhancing Performance of PCBAs Using Plasma Treatment
Aug 03, 2017 -
Revolutionary AOI, AXI and & Bondtesting from Nordson at NEPCON South China
Mar 07, 2017 -
Nordson MARCH Wins 2017 New Product Introduction Award for its ModVIA Plasma System
Feb 07, 2017 -
Nordson MARCH's New Plasma Polymerization Deposition Systems Deposit Materials During Precision Manufacturing Processes
8 more news from MARCH Products | Nordson Electronics Solutions »
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Nordson MARCH MesoSPHERE Plasma Systems Enable Very High Throughput Processing for 3D and Wafer-level Package Assembly news release has been viewed 1104 times
