  • EMS introduces 5 μm thick dry film negative photoresist DF-3505 for metallization processes
Sep 27, 2018
Engineered Material Systems, Inc., a leading global supplier of negative photoresist materials, is pleased to introduce the availability of its DF-3505 series dry-film negative photoresists for wafer level metallization processes. This material formulation has been optimized for hot roll lamination and processing on MEMS and IC wafers.
The DF-3505 dry-film resist also can be used to create permanent features on wafers. When used in conjunction with the 412-17 EMS adhesion promoter, the resist is capable of surviving HAST testing on silicon wafers. This dry-film is capable of extreme fine line and space definition in complex patterns with resolutions down to 3μm for the DF-3505. The cured chemistry can withstand harsh environments including resistance to extreme moisture conditions and corrosive chemicals.
EMS DF-3505 dry-film photoresist is tougher (less brittle) than other negative photoresists on the market with glass transition temperatures ranging from 120°C (by DMA Tan Delta) to 200˚C. The material is hydrophobic in nature, providing chemical and moisture resistance. EMS dry-films are compatible with and can be used in contact with the EMS line of spin-coatable negative tone photoresists.
The DF-3505 dry-film negative photoresist is the latest addition to Engineered Materials Systems’ full line of film and liquid negative photoresists formulated for lift off processes, via sealing and making microfluidic channels on MEMS devices.
For more information about the dry film negative photoresist or to learn how Engineered Materials Systems can define, develop and create an engineered material solution that is right for your company, visit www.emsadhesives.com.
Dec 04, 2019 -
Jun 15, 2019 -
May 13, 2019 -
Apr 15, 2019 -
Feb 21, 2019 -
Jan 15, 2019 -
Sep 13, 2018 -
Sep 05, 2018 -
Jun 11, 2018 -
May 08, 2018 -
Sep 18, 2024 -
ABB NTCS04 infi90 CONTROLS MODULE TERMINATION UNIT
Sep 18, 2024 -
ABB SPCIS22 l/O Control Module
Sep 18, 2024 -
ABB SPDSM04 Module installation unit
Sep 18, 2024 -
ABB NTRO12-A Analog input Terminal
Sep 18, 2024 -
ABB SPDSO14 Digital output Module
Sep 18, 2024 -
ABB NTDI21-A Inverter Circuit Board PCB
Sep 18, 2024 -
ABB SPDSI22 Digital input Module
Sep 18, 2024 -
ABB SPDSI14 Analog input module
Sep 18, 2024 -
ABB NKAS01-15 infi 90 Termination Cable
Sep 18, 2024 -
ABB NTAI06 terminal board
EMS introduces 5 μm thick dry film negative photoresist DF-3505 for metallization processes news release has been viewed 1155 times
SMT Feeders
