  • SMT 158 -- A Underfill Solution for Miniaturization in Microelectronics
May 13, 2015
The current trend of miniaturization in microelectronics have paved the way for 3D packaging; allowing for lower manufacturing cost, increased memory and speed and a greater variation in functional uses of the miniaturized devices. While miniaturization has afforded consumers with convenience and greater ease of use, manufacturers have been faced with problematic issues in light of the reduction of the standard bump size in 3D packaging from 80 µ to 10 µ.  Using nanoformulations, YINCAE Engineers have successfully crafted an array of solutions in response to issues that standard underfills have, particularly with flowability through the gaps between the bumps ≤ 10 µ.
In a recent study examining standard underfills for multilayer low bump 3D Packaging, YINCAE Advanced Material’s SMT 158 was compared against three other standard manufacturing underfill materials from leading suppliers. The results of this comparison are astounding. In reliability testing that included thermal cycling, flowability and pressure cooking, SMT 158 outperformed the other three materials in every stage of testing. Most noteworthy perhaps is that SMT 158 can flow up to 4 times faster than the other three.  The thermal cycling for the other three materials ranged from 800-1000 cycles before failure. SMT 158 did not fail until 3500 cycles, indicating a significance of reliability that far exceeds current industry standards.
With industry advancements using nanotechnology, the need to improve or completely eliminate undefill is imminent. YINCAE offers Advanced Material solutions that far exceeds the standard manufacturing protocol with smaller filler particulate and significantly faster curing underfill in addition to solder joint encapsulation adhesives that can be used in place of underfill at the same point in any reflow profile. Be sure to visit our web page www.yincae.com to learn more.
Jun 22, 2023 -
YINCAE Launches Snap Cure, Highly filled ,100% No-Clean Flux Residue Compatible Underfill: UF 120HA
Mar 27, 2023 -
YINCAE Launches Breakthrough Thermal Underfill: UF 158A2
Nov 08, 2022 -
YINCAE Advanced Materials Wins Global Technology Award at SMTAI 2022 for Adhesives/Underfills/Encapsulants
Aug 16, 2022 -
YINCAE's Fully Flux Residue Compatible Underfill: UF 158HA
Mar 30, 2022 -
YINCAE's DA158N Die Attach Materials withstanding -273°C
Dec 22, 2021 -
Fully Flux Residue Compatible, Room Temperature Fast Flow, Reworkable Underfill SMT 88UL2
Feb 24, 2021 -
YINCAE's New SMT 158N Series withstanding -273°C
Jan 21, 2021 -
World's First Commercially Available Diamond Filled Underfill: SMT 158D8
Aug 04, 2020 -
YINCAE Advanced Materials, LLC. Proudly Announces ISO 9001:2015 Certification
Sep 05, 2019 -
YINCAE To Exhibit at IMAPS 2019 Boston 52nd International Symposium Just 1 Month Away! Visit YINCAE at Booth #530
48 more news from YINCAE Advanced Materials, LLC. »
SMT 158 -- A Underfill Solution for Miniaturization in Microelectronics news release has been viewed 764 times
Manufacturing Software
