  • Saelig Introduces Flicker Spectrometer To Quantify Light Flicker Measurements
Dec 21, 2018
GL Spectis 1.0 Touch Flicker Spectrometer from Saelig
Saelig Company, Inc. (www.saelig.com) has introduced the GL Spectis 1.0 Touch Flicker Spectrometer, an upgraded version of the very successful handheld Spectis 1.0 Touch Spectral Light Meter.  This device can now measure the increasingly important parameter of light flicker in addition to the extensive range of standard photometric and colorimetric values already available.  The Spectis 1.0 Touch Flicker Spectrometer is now equipped with additional electronics and a fast photodiode to measure flicker frequency, flicker index, and flicker ratio. Designed and developed in consultation with industry leaders and standards committees, this device provides all the measurement quantities required to accurately measure and understand flicker.
With new LED lighting applications, the problem of flicker in slow-motion video has resurfaced.  Previously, this was a very common phenomenon with fluorescent lighting, but as technical improvements were made to the ballasts, the problem was largely eliminated. Today the main source of such flicker is LED lighting, caused by the driving circuitry supplying power to the lights.  For sports facilities, having optimal illumination with minimal light flicker is important to consider when installing LED lighting.  For instance, at FC Chelsea's famous Stamford Bridge Stadium (Fulham, London, UK) the existing lighting was recently replaced with LED fixtures that can create unique illumination effects and light displays.
The new mobile GL Spectis 1.0 Touch Flicker spectrometer from GL Optic is suitable for measuring flicker in the signal range 0.1Hz – 12.5kHz. The user can take measurements of light sources and LED floodlights. To fully characterize and compare light sources, the GL Spectis 1.0 T Flicker can process recognized flicker parameters such as flicker frequency, flicker index and flicker factor. The instrument can also be used to capture other photometric and colorimetric data such as illuminance, colorimetric locus and color rendering index, displaying the analysis results on the color touchscreen. The GL Spectis 1.0 Touch Flicker can be used to detect, characterize, and ultimately avoid flicker issues. Covering an exceptionally wide range of frequencies, this device offers accuracy equal to many laboratory devices.
Flicker-free lighting is extremely important for slow-motion replays that show home TV viewers exactly what happened, something which is now taken for granted in professional sports. At frame rates up to 480 fps for slow-motion sequences, modulation of the artificial light output can produce perceptible brightness variations. Normally, up to a certain frequency, human persistence of vision compensates for light modulation, which is why fluctuations in light caused by the alternating current powering lights are not normally noticed. During the planning and design phase, the use of a professional light meter like this is essential to verify the proposed lighting system has minimal flicker.
GL Optic light measurement instruments were recently used during installation of the new LED playing field lighting at Chelsea Football’s Stamford Bridge Stadium , UK.  Mike Simpson, Director of Engineering & Design at Philips Lighting, stressed that "The GL Optic device allows us to rapidly and accurately assess the quality of LED-based lighting installations. The GL Spectis 1.0 Touch is a very fast spectrometer and easy to use in the field”.
Designed and made in Europe by GL Optic, a leading supplier of standardized light solutions, the  GL Spectis 1.0 Touch Flicker Spectrometer is available now from GL Optic’s USA distributor SaeligCompany. Inc. (NY).
Feb 09, 2024 -
Jul 20, 2023 -
Apr 06, 2023 -
Dec 13, 2022 -
Mar 18, 2022 -
Mar 11, 2022 -
Feb 16, 2021 -
Dec 03, 2020 -
Oct 23, 2020 -
Oct 14, 2020 -
Sep 12, 2024 -
Sep 12, 2024 -
Sep 12, 2024 -
Sep 12, 2024 -
SIEMENS 6EW1810-3AA
Sep 12, 2024 -
Sep 12, 2024 -
ABB DAI04 1 year warranty
Sep 12, 2024 -
LP HCW222A PLC MODULE
Sep 12, 2024 -
ABB DSRF182 57310255-AL
Sep 12, 2024 -
Sep 12, 2024 -
Saelig Introduces Flicker Spectrometer To Quantify Light Flicker Measurements news release has been viewed 1160 times
