  • Saelig Introduces JRE TVK Isolation Tester for Shielding and Shielded Enclosures
Feb 16, 2021
JRE TVK Isolation Tester for Shielded Enclosures from Saelig
Saelig Company, Inc. has introduced the JRE TVK Isolation Tester, which can help to verify the proper shielding isolation of RF enclosure test set-ups.  This test combination, consisting of the STA-1, a sensitive handheld spectrum analyzer, and the HPSS-1, a high power 2.45GHz test signal source, can easily and quickly measure enclosure isolation down to less than -100dB.  The TVK Isolation Tester is simple to use since it is completely adjustment free, which eliminates erroneous readings or complex spectrum analyzer adjustment.
The HPSS-1 RF signal source, enclosed in a compact, rugged extruded aluminum case, is designed to be placed inside the sealed test enclosure being investigated.  The HPSS-1 produces a high power 250-500mW 2.45GHz signal which is necessary for sensitive leak detection.  A high capacity internal Li-Ion battery allows stand-alone operation, eliminating the need for an external power supply or the need to feed power into the test enclosure. In this way the enclosure isolation barrier is unimpeded and uncompromised. The STA-1 handheld spectrum analyzer is factory-configured to a center frequency of 2.45GHz, with a span of 2MHz and a dynamic range on-screen of 115dB. With the directional antenna provided, it is a simple task to search for any signal leakage problems, such as leaky gaskets, seams, or loose screws.
The economical JRE TVK Isolation Tester is made by JRE Test LLC, which develops, designs, and produces custom and fast-turnaround RF shielded test enclosures and test equipment.  It is available now from their USA distributor Saelig Company, Inc., Fairport, NY.
Feb 09, 2024 -
Jul 20, 2023 -
Apr 06, 2023 -
Dec 13, 2022 -
Mar 18, 2022 -
Mar 11, 2022 -
Dec 03, 2020 -
Oct 23, 2020 -
Oct 14, 2020 -
Jun 30, 2020 -
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Fluid Dispensing Aerospace
