  • Saelig Introduces Economical Sensepeek SQG Passive 6GHz Probe Series
Jan 31, 2025
Saelig Company, Inc. has introduced the Sensepeek  SQG-series of passive high-frequency hands-free oscilloscope probes, designed for both AC and DC GHz applications. When used with Sensepeek baseplates or handheld, this groundbreaking series enables engineers to perform measurements up to 6GHz economically and without the need to solder connections to the test PCB.
Maintaining measurement signal integrity is crucial, and the SQG-series has exceptionally low probe-tip capacitance, which minimizes loading and signal distortion for sensitive circuits. Measuring high data rate signals is now economical and precise with these passive probes that offer a flat frequency response over a wide frequency range.  The series is available as either AC or DC-coupled probes for precise signal integrity measurements across a wide range of uses. Other low-impedance probes can load the signal being probed, reducing its amplitude. For DC biassed signals, these inferior probes can source or sink current from the signal source, potentially affecting the operating bias of sensitive devices. But by reducing the probe’s loading effect and ensuring consistent broadband performance, waveforms and their spectral content and phase are not adversely affected by SQG probes.
AC-coupled probing is particularly advantageous when working with DC-biased data streams, such as those found in high-speed interfaces like USB, HDMI, and SATA, or differential signaling standards like ECL and PECL.  AC-coupled probes are also ideal for examining small, high-frequency signals on supply lines or control circuits, critical for diagnosing issues such as power supply noise, current ripple, or decoupling inefficiencies.
The six members of the Sensepeek SQC 10:1 passive probe series are: 1.5GHz: SQG15-AC / SQG15-DC – 1.5 GHz; 3.0GHz: SQG30-AC / SQG30-DC; 6.0GHz: SQG60-AC / SQG60-DC. The SQG-series is suitable for use with any 50 ohm input measurement instrument, including: oscilloscopes, spectrum and network analyzers, receivers, power meters, etc.
The SQG-series is ready-to-go straight out of the box.  They include exchangeable fine-pitch spring-tipped test needles, ensuring reliable contact with small or delicate components. The dual ground options, a dual needle ground with a 2.3mm tip pitch, perfect for PCB-mounted RF connectors, and a solid single ground with a 6.5mm tip pitch, designed for when ground points are farther away, make this probe adaptable to a wide variety of needs.
The SQG-series is the ideal solution for engineers looking for precision, stability, and ease of use in high-frequency measurements.  For troubleshooting power integrity problems or analyzing signal fidelity in high-speed digital designs, Sensepeek’s range of AC and DC-coupled probes offers the versatility and precision that high-frequency and electronics engineers demand. SQG probes are made in Sweden by Sensepeek AB.  It is available now from their from USA technical distributor Saelig.
Jan 16, 2025 -
Saelig Introduces the Langer EMV P1 Mini Burst Generator Kit For Evaluating PCB B- and E-field Vulnerabilities
Feb 09, 2024 -
Jul 20, 2023 -
Apr 06, 2023 -
Dec 13, 2022 -
Mar 18, 2022 -
Mar 11, 2022 -
Feb 16, 2021 -
Dec 03, 2020 -
Oct 23, 2020 -
73 more news from Saelig Co. Inc. »
Mar 06, 2025 -
MCVH Connectors: Power M23 Solutions for Harsh Environments
Mar 04, 2025 -
XJTAG to launch new products at APEX and Embedded World
Mar 04, 2025 -
PCBA Insight: Reading a PCB Board
Mar 03, 2025 -
KIC to Demo Next-Generation TAS Software at SMTA Dallas Expo & Tech Forum
Mar 03, 2025 -
Aven to Show New ProVue MAX Magnifying Lamps and E-Z Grip Tweezers at SMTA Dallas & Houston Expo & Tech Forums
Mar 03, 2025 -
Best Technical Papers at IPC APEX EXPO 2025 Selected
Mar 03, 2025 -
Essemtec introduces new machine models enhancing pick-and-place speed with FOX Ultra and PUMA Ultra
Mar 03, 2025 -
Koki Americas Welcomes Greg Starrett as National Sales Manager
Mar 03, 2025 -
Nordson TEST & INSPECTION to Unveil Next-Generation Inspection and Metrology Technology at APEX
Mar 03, 2025 -
Naprotek Secures Over $9M in FY24 Contracts for SDA Tracking Programs
Saelig Introduces Economical Sensepeek SQG Passive 6GHz Probe Series news release has been viewed times
