  • Introducing the LCR13, a stackable, fully programmable, 13mm wide electric linear rotary actuator.
Dec 18, 2014
SMAC LCR13 Series Linear Rotary Actuator
SMAC Moving Coil Actuators, Inc. introduced the LCR13, a new range of electric linear rotary actuators only 13mm in width. The LCR13 has a compact direct-drive brushless servo motor. The precision Z-theta motion within one small actuator, provides a convenient pick, orient and place. The LCR13 has a light moving mass of 95 grams, which results in high accelerations. The vacuum-built-in shaft through the rotary motor is available to prevent dust build-up in the unit. The LCR13 can easily be programmed to control force/torque, position and velocity in all axes at the same time with feedback capability.
Technical Specifications:
• Dimensions [mm]: 75 x 155 x 13
• Stroke [mm]: 25 (+1/-0)
• Peak Force [N]: 7 @ 3A
• Linear Encoder Resolution [µm]: 5 standard, 1 optional
• Peak Torque [Nm]: 0.047 (24VDC)
• Rotary Encoder Resolution: 6K or 24K/Rev
• Combined linear and rotary motions in a single unit
• Fully programmable in force/torque, position and velocity
• SMAC’s Patented ‘Soft-Land’ Technology
• Low shaft run-out, 30µm (Lower run-out optional)
• Self-lubricated linear guide
• Vacuum through shaft prevents dust accumulation
• Spring option
As with all SMAC actuators, the LCR13 is fully programmable in position, velocity and force simultaneously. They are designed for fast and easy setup via Graphical User Interface for different product profiles. This results in significant savings of time and cost, and improved throughput by reducing equipment down time. SMAC’s patented “Soft-land” function ensure precise contact force. As a standard feature, 100% data feedback is provided.
Sep 14, 2024 -
DELKIN DEVICES CE02TFNHK-FD000-D
Sep 14, 2024 -
HONEYWELL 8C-TDOD51 Digital input Module
Sep 14, 2024 -
SIEMENS 7TS4022-1/BB
Sep 14, 2024 -
HONEYWELL FS-USI-0001 UNIVERSAL SAFETYINTERFACE MODULE
Sep 14, 2024 -
ABB 3BHB003387R0101 5SXE 05-0151 5SHX 08F4502
Sep 14, 2024 -
KETOP T50 R01 VX/69908/14 Discrete Output Module Cable 5m
Sep 14, 2024 -
ABB HIEE401481R0001 UAC326 AE01
Sep 14, 2024 -
GE TGT-AIOV-8-0 Analog l/0 Module
Sep 14, 2024 -
GE IS220PDOAH1B Discrete Output Module
Sep 14, 2024 -
ALSTOM 8933-0000 Regelsatz
Introducing the LCR13, a stackable, fully programmable, 13mm wide electric linear rotary actuator. news release has been viewed 1302 times
