Graphicode’s GC-Prevue v22.3 supports new Gerber X2 format.
Jul 30, 2014
Graphicode is pioneering a wave of developments in PCB software that promises to revolutionise the PCB design to manufacture process: the latest version of its GC-Prevue software now fully supports Ucamco's groundbreaking second extension Gerber X2 format.
Introduced earlier this year, Gerber X2 delivers unprecedented clarity to the CAD-to-CAM data transmission process. It does this by supporting the tried and tested Gerber image format with an equally clear and easy-to-use standard for all the additional data that precisely and reliably describes the image components. This includes details on stackup, the functions of layers and individual features such as pads, and a host of other parameters. With Gerber X2, designers can now rest assured that their manufacturing partners have all the data – and clarity – needed for efficient, reliable manufacture.
All without disrupting existing procedures, as Ucamco's Managing Director Karel Tavernier emphasises: "While X2 represents a revolutionary step towards unequivocal communication, it maintains the trademark simplicity for which Gerber has always been known and used, requiring very little change to working practices, and certainly none that would require approval, testing and all the rest".
The new development centres on the use of standard attributes to define a number of key parameters. These attributes were carefully selected by Ucamco to maximise efficiency improvements in CAD-to-CAM communications by describing characteristics such as:
  • Gerber file function:  top copper layer, top solder mask, etc.
  • Part: single PCB, customer panel etc.
  • Object function: SMD pad, via pad etc
  • Drill tolerances
  • Locations of impedance-controlled tracks
  • Filled vias
  • An MD5 checksum for added security
As the creator of GC Prevue, the PCB industry's leading image format viewer and the first to be offered freely to the PCB industry, Graphicode was a natural partner for Ucamco's development of the X2 format. Graphicode's Paul Wells-Edwards explains: "Used by countless PCB professionals globally and throughout the PCB pre-production process, GC-Prevue is the industry's de facto standard Gerber viewer, so we have worked closely with Ucamco and Gerber for years. The beauty of Gerber is that it's simple, and very widely used, and Ucamco's use of attributes is a very clever and straightforward way to improve and build on it. By extending the format and making it far clearer, Ucamco has improved the CAM task no end. When the opportunity arose to participate in that improvement, we jumped at it.” He adds that the implemention of X2 is simple and straightforward, given that it consists of just 3 new commands and a clear list of standard attributes: “It took us just a week and a half of coding to be able to add the necessary information, so it's a very small step for any CAM system to be able to handle it”.
Other software companies are following suit, according to Tavernier: "Altium, global leader in Smart System Design Automation, and creator of Altium Designer, has also been quick to recognise the value of X2 and will support it in the upcoming version of Altium Designer. Furthermore, I was recently informed that DipTrace and Kicad will output X2 in the course of 2014, and LPKF will support it from Q1 2015. Eurocircuits and AT&S offered to beta test it, and it will be in real production by the end of 2014, less than 12 months after its introduction”.
X2 will boost productivity most and bring maximum benefits when used with fully X2-compatible software, enabling the whole Gerber archive to be read automatically, with all layers in place, while identifying the function of each object. And it's easy to use, says Wells-Edwards: "Adding intelligence to the core Gerber format is much simpler than people imagine. The reward is immense: a far better way of transferring data”. But even if X2 is used with older, non-compatible software, it will still generate the correct image – as demonstrated by the sample PCB jobs that can be downloaded from www.ucamco.com. This shows the format's upward compatibility, as well as the beauty and simplicity of the X2 concept. Tavernier: “Nobody is forced to buy anything to adopt X2. All users can happily use it with no problems, deciding in their own time if, how and when to adopt new X2-ready software to take their processes to the next level”.
Gerber X2 file format specification, sample X2 archives and background articles on X2 are available for download.
GC Prevue v 22.3 with X2 support is available for download.
Ucamco (formerly Barco ETS) is a market leader in PCB CAM software, photoplotting and direct imaging systems, with a global network of sales and support centers. Headquartered in Ghent, Belgium, Ucamco has over 25 years of ongoing experience in developing and supporting leading-edge photoplotters and front-end tooling solutions for the global PCB industry. Key to this success is the company's uncompromising pursuit of engineering excellence in all its products. Ucamco also owns the IP rights on the Gerber File Format through its acquisition of Gerber Sytems Corp. (1998).
GraphiCode is a global provider of software innovations for electronics manufacturing. Our products and services facilitate the fabrication, test, inspection and assembly of Printed Circuit Boards. We supply specific programming solutions to equipment manufacturers. We also provide value-added services through an international distributor network. GraphiCode’s commitment to providing exceptional support and services ensures successful integration of our products into the manufacturing process.
Feb 19, 2024 -
UcamX and Integr8tor v2023.12 are now available
Nov 20, 2023 -
Ucamco Launches Jayda: A Revolutionary Web-Based Quoting Tool with Dynamic Graphics
Nov 20, 2023 -
LeVina: Direct Imaging for next-gen packaging substrates
Jul 16, 2022 -
UcamX and Integr8tor v2022.06 press release
Jul 08, 2022 -
New version of Reference Gerber Viewer freeware
Jul 19, 2021 -
New Gerber Job Editor now accepts notes in Chinese
Mar 12, 2021 -
New Gerber Layer Format Specification
Jan 17, 2021 -
IPC-DPMX import in upcoming Integr8tor and UcamX releases
Sep 17, 2020 -
Ucamco releases Integr8tor v2020.08, introduces UcamX Workflow Edition (WE)
Jul 09, 2019 -
Simple, streamlined CAD-to-CAM communications
12 more news from Ucamco »
Jul 19, 2024 -
Electronica 2024: Where Vision Meets Reality
Jul 18, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Graphicode’s GC-Prevue v22.3 supports new Gerber X2 format. news release has been viewed 1512 times
Manufacturing Software
