Flexible test fixture concept reduces investment costs
Apr 12, 2013
Cost-efficient test fixture for incircuit and function tests
New flexible test fixture
For pre-series and early production the exchange set can be used in a cost-efficient test fixture. Only minimum retrofit is required to use the same component in an inline-contact cell. The charm of this solution is that the initial investment required when starting the production of a new board is relatively low and will only go up as production volumes increase. The standardized module system facilitates the simple and fast conversion of equipment, which in turns also means optimum flexibility with regard to production sites.
Our specialists at the exhibition will gladly demonstrate how you can benefit from it. Visit us at our Stand 434 in Hall A6.
Based on many years of experience, ENGMATEC offers a high degree of functional reliability, short realization periods and an attractive price-performance ratio.
Flexible test fixture concept reduces investment costs news release has been viewed 2564 times
