  • PVA Highlights Jet Coating and Meter-Mix Dispensing System at SMTA Atlanta
Mar 31, 2019
PVA’s MX4000 Gear Pump Meter-Mix Dispensing System.
PVA, a global expert in dispensing, coating and custom automation, will exhibit at the exhibit at the SMTA Atlanta Expo, scheduled to take place Thursday, April 11, 2019 at the Atlanta Technology Park in Peachtree Corners, GA. Company representatives will discuss PVA’s Jet Coating and Meter-Mix Dispensing System.
PVA’s MX4000 Gear Pump Meter-Mix Dispensing System is a robust system designed to control non-abrasive meter-mix dispensing applications such as potting and encapsulation, conformal coating, form in place gasketing, laminating, sealing, and adhesive/assembly operations. Used in automotive, electronics, solar & wind energy, aerospace, and other industries, the gear pump processes a wide range of adhesives and sealants while providing continuous material flow with no recharging necessary.
For repeatability and dispense volume accuracy, closed-loop servo drives enable the operator to program the mix ratio, shot size, flow rate, pressure control, vacuum degas, recirculation and auto purge functions using a menu-driven HMI.
Also included with the system are these integrated features; continuous pulse-free flow, high-pressure capability up to 4000 psi, wide viscosity range to 3 million cps, and superior resolution as pumps are sized to each requirement — all allowing the system to be customized to specific applications.
For more information, please contact PVA at info@pva.net or (518) 371-2684. PVA is a global supplier of conformal coating systems, innovative fluid dispensing solutions and precision valve technology. PVA’s customer driven solutions are utilized worldwide in industries ranging from solar, semiconductor packaging, printed circuit board assembly, medical device manufacturing, and consumer electronics. Throughout the changing global manufacturing landscape, PVA remains committed to providing our customers with exceptional products and industry-leading global support.
Jun 03, 2024 -
May 27, 2024 -
May 27, 2024 -
PVA to Present Cutting-Edge Coating Technology at PB Technik's Premier Event in Warsaw
May 20, 2024 -
PVA to Show State-of-the-Art Conformal Coating Solutions at SMTconnect 2024
Apr 03, 2024 -
PVA's Jon Urquhart to Present at SMTA Heartland's STAR Forum on High Reliability Electronics
Mar 18, 2024 -
PVA to Showcase PathMaster X at APEX – Redefining Precision and Control in Production
Mar 11, 2024 -
PVA Secures 2024 NPI Award for New Direct Series with PathMaster X
Mar 04, 2024 -
PVA to Showcase Advanced Conformal Coating and Dispensing Solutions at productronica China 2024
Feb 26, 2024 -
PVA Discusses PathMaster X Programming Software at SMTA Dallas Expo & Tech Forum
Dec 18, 2023 -
PVA Unveils State-of-the-Art Applications Lab in Guadalajara, Mexico
112 more news from Precision Valve & Automation (PVA) »
PVA Highlights Jet Coating and Meter-Mix Dispensing System at SMTA Atlanta news release has been viewed 1010 times
