  • Dispensing, Coating and Custom Automation Equipment from PVA at productronica
Oct 17, 2019
PVA today announced that it will be running live dispensing demos in Hall A2, Booth #253 at productronica, scheduled to take place Nov. 12-15, 2019 at the Neue Messe München in Munich, Germany. Demos will be available for the following equipment: Delta 8 with MR2, Delta 8 featuring a PCS150 & PC150 fed by a VPK-2K for 2K coating, Delta 8 equipped with a FCS300-ES, SJ100 & FC100-CF for film coating, and Delta 6 configured for PCB assembly (surface mount adhesive, underfill, encapsulation, etc.).
Designed for multiple applications, the Delta 8 System is flexible beyond conformal coating. The MR2 highlights the Delta 8’s fluid dispensing capabilities. The MR2 is a versatile servo-controlled rod dispenser for processing single or dual component chemistries requiring a high level of dosing accuracy.
Utilizing a volumetric displacement concept, the MR2 is capable of processing a wide range of chemistries, including viscous filled or abrasive materials, without concern to slight material changes from batch-to-batch or due to atmospheric conditions. This results in a more accurate dispensing process for difficult to process chemistries.
The Delta 6 is a flexible robotic conformal coating/dispensing system that is ideal for selective coating, potting, bead, and meter-mix dispensing applications. The robust overhead three-axis motion platform is suitable for inline or batch operations. The Delta 6 has a slim footprint, rigid structure, and robust gantry configuration designed for high accuracy and demanding applications.
Experts from PVA will be on hand in the booth to answer any questions about dispensing and coating, as well as other application solutions in the PVA line-up such as coating inspection, optical bonding and curing ovens.
For more information, please contact PVA at info@pva.net or (518) 371-2684.
PVA is a global supplier of conformal coating systems, innovative fluid dispensing solutions and precision valve technology. PVA’s customer driven solutions are utilized worldwide in industries ranging from solar, semiconductor packaging, printed circuit board assembly, medical device manufacturing, and consumer electronics. Throughout the changing global manufacturing landscape, PVA remains committed to providing our customers with exceptional products and industry-leading global support.
Jun 03, 2024 -
May 27, 2024 -
May 27, 2024 -
PVA to Present Cutting-Edge Coating Technology at PB Technik's Premier Event in Warsaw
May 20, 2024 -
PVA to Show State-of-the-Art Conformal Coating Solutions at SMTconnect 2024
Apr 03, 2024 -
PVA's Jon Urquhart to Present at SMTA Heartland's STAR Forum on High Reliability Electronics
Mar 18, 2024 -
PVA to Showcase PathMaster X at APEX – Redefining Precision and Control in Production
Mar 11, 2024 -
PVA Secures 2024 NPI Award for New Direct Series with PathMaster X
Mar 04, 2024 -
PVA to Showcase Advanced Conformal Coating and Dispensing Solutions at productronica China 2024
Feb 26, 2024 -
PVA Discusses PathMaster X Programming Software at SMTA Dallas Expo & Tech Forum
Dec 18, 2023 -
PVA Unveils State-of-the-Art Applications Lab in Guadalajara, Mexico
112 more news from Precision Valve & Automation (PVA) »
Dispensing, Coating and Custom Automation Equipment from PVA at productronica news release has been viewed 892 times
