  • Japan Unix’s Flash Soldering Series Doubles Speed with New Optical Laser Configuration
May 26, 2015
Flash Soldering Series.
Japan Unix, a solutions provider for manual and soldering automation, announces a speed upgrade to its flash soldering Unix FS Series. The innovative flash soldering laser system is two times faster than a typical laser and can integrate pre- and post-soldering processes such as surface mount and through-hole devices. In addition to increasing speed, the Series can improve productivity.
A new, integrated optical laser configuration achieves “double speed” on the updated FS Series. At less than 0.3 sec per point, the system can accomplish anything from SMT to through-hole soldering with unbelievable speed. Flash soldering not only saves power consumption but also reduces maintenance.
The Unix FS Series focuses on three main elements:
Speed: Depending on various conditions, 100 points can be soldered in less than 30 seconds, which significantly increases productivity. A regular laser provides <0.5 sec/point while Japan Unix’s laser does the same in <0.25 sec/point.
Integration: Featuring integrated soldering process for both solder paste and wire, the FS Series has a coaxial camera that follows actual soldering work scenes. It also has a simple setup and operation with direct teaching and soon will feature automatic correction and error detection. Additionally, it is possible to integrate pre- and post-soldering.
• The series’ compact size saves both space and power consumption compared to flow and reflow machines. Additionally, its footprint is compact enough to fit into any system scale, and its fixed soldering work area successfully reduces space.
To watch the Flash Soldering FS Series in action, watch the following videos:
• Flash soldering to 103 chip resisters (0.2 x 0.04 inches): https://www.youtube.com/watch?v=aBOuAHz3TSU
• Integrated soldering processes, both SMT and through-hole: https://www.youtube.com/watch?v=iIs4sGodiOI
For more information about Japan Unix’s Flash Soldering System Series, visit https://www.japanunix.com/en/products/laser/flash.php. Contact Japan Unix at www.japanunix.com to ensure the FS Series can be exported to your country.
Japan Unix was established in 1974 in Tokyo and has specialized in the soldering automation industry since its startup. A manufacturer and integrator of robotic soldering, Japan Unix offers production systems with advanced soldering methods that provide a high-speed quality soldering solution for automotive, medical, aerospace and electronics manufacturers. The company offers a wide range of soldering robots with a strong competency in precision soldering and factory automation.
Jul 21, 2016 -
Japan UNIX Launches Robotic Soldering Modules to Automate Soldering Operations
Feb 15, 2016 -
Join Japan Unix at the IPC APEX EXPO for New Laser Soldering Solutions
Sep 22, 2015 -
Japan Unix to Exhibit Desktop Soldering Robots at SMTA Guadalajara 2015
Jun 02, 2015 -
Japan Unix Can Reduce PCB Burning Issues with Optimal Laser Shape Rings
May 19, 2015 -
Optimize Laser Soldering with Japan Unix’s New Multi-Phi Technology
Jan 22, 2015 -
Jan 12, 2015 -
Japan Unix Makes Power & High-Temp Webinar Available in Japanese
Jun 12, 2024 -
Jun 11, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Japan Unix’s Flash Soldering Series Doubles Speed with New Optical Laser Configuration news release has been viewed 1245 times
