  • Gen3 Systems to Exhibit New SIR and CAF Systems with Ascentech LLC at the IPC APEX EXPO
Feb 02, 2015
AutoSIR 2 Measurement system.
Gen3 Systems Limited, a specialist British manufacturer and distributor, today announced that it will exhibit at the IPC APEX EXPO alongside its North American Distributor Ascentech LLC.  Gen3 Systems will be present on Booth #1028 at the IPC APEX EXPO, scheduled to take place Feb. 24-26, 2015 at the San Diego Convention Center, San Diego, and will introduce new and improved products for electronics manufacturing at the trade show.
GEN3 has redesigned its line of Surface Installation Resistance Testers (AutoSIR) and Conductive Anodic Filament Monitoring Testing System (AutoCAF)
The key features of both the NEW AutoSIR 2 and AutoCAF 2 Measurement systems provide the following product enhancements:
  • Measurement Time: 256 Channels <8 seconds
  • Applied Voltage: +1V to 1000V
  • Measurement Range: 106 ω to 1014 ω
  • Measurement Method: Continuous on all selected tests
  • Measurement Test Intervals: Fully selectable from minimum of one minute
  • Capable of testing to all existing test specifications IPC - IEC - JNC and other user specifications
Unlike the original instruments, the use of switch relays is eliminated so that, when the test and measurement voltages are the same, truly continuous monitoring and measurements can be made.
Measurements may be taken at test intervals that are fully selectable from a minimum of one minute. Each channel is current limited (1 Mω), ensuring that Electro-Chemical Reactions (Dendrites) are preserved for subsequent failure analysis. The frequent monitoring capability provides a full picture of the electro-chemical reactions taking place on a circuit assembly, and provides early trend analysis enabling tests to be curtailed, thus saving considerable test time and money.
Both the AutoSIR 2 and AutoCAF 2 Systems are available with 64, 128 or 256 channel configurations.
Graham Naisbitt, Managing Director of Gen3 commented, “The features of the new AutoSIR and AutoCAF instruments provide significant performance improvements at a highly competitive price. Much of the developments were achieved through our participation on a major CAF Research Project conducted by our NPL. We believe that the ability to measure from 256 test channels in less than 8 seconds is industry-leading and the IPC APEX EXPO is the perfect Launchpad for these new products.”
Gen3 also will exhibit the Gensonic Stencil Cleaning System, awarded the European Product of the Year at Productronica 2013, which is a manual operated ultrasonic transducer unit for cleaning stencil apertures.
The Gensonic can be used either in conjunction with Gen3’s Stencil Cleaning Centres or is portable enough to be taken directly to the printer thereby greatly reducing production downtime and printer resetting.
The Solder-Saver offers companies that use wave soldering the opportunity to instantly recycle dross created in the wave solder pot, thereby saving up to 50 percent in new solder bar purchases. It can be used with tin – lead alloy or lead-free alloy wave soldering machines.
Also available in Gen3’s manufactured product line is the Ionic Contamination Systems, also known as the CM Series, Dip and Spray Coating Systems, MUST III Solderability Testing System (wetting balance), Wizard Thermal Profiling and Solder Paste Inspection.
For more information about Gen3 Systems, visit www.gen3systems.com.
Gen3 Systems is a specialist manufacturer of test and measurement equipment used to help predict reliability of electronic circuits and systems in the field. In addition, the company designs and manufactures dip and spray coating process equipment in both in-line and bench-top formats. Gen3 is a specialist distributor for several leading equipment manufacturers including, ACE, DIMA, FineTech, MBTech, MEK, Optilia and, most recently, Global Distributor for Aprotec Instrumentation, Solder Paste Inspection (SPI) systems.
Gen3 Systems also provides training, equipment and expertise for manufacturers requiring assessment of their electronic products’ reliability. The company also operates a test service and assists with standards development via both the IPC and IEC. Gen3 Systems operates from premises near Farnborough Business Park, on the M3 corridor and just 30 minutes from London’s Heathrow Airport.
Ascentech, LLC is a North American Distributor of Products and Services for Electronics Manufacturing and Printed Circuit Board Fabrication. Ascentech is the North American Distributor for GEN3 Systems, and supplies the industry with other product reliability test equipment including the MUST III -Solderability test systems (wetting balance), Auto-SIR -Surface Insulation Resistance test, CM-Series - Cleanliness test (ionic contamination), and the SPA-1000-Solder Paste Analyzer. To learn more about the company visit www.ascentechllc.com
Jun 17, 2024 -
May 13, 2024 -
GEN3's Graham Naisbitt Speaks with Nolan Johnson on the Crucial Topic of Objective Evidence and the New IPC J-STD-001 Standard
Mar 11, 2024 -
GEN3 to Demo SIR Testing, Stencil Cleaning & More with Horizon Sales at APEX
Feb 05, 2024 -
GEN3 to Showcase Advanced Inspection and Testing Solutions at the Southern Manufacturing & Electronics Expo
Jan 15, 2024 -
Gen3 to Release Next Generation CM Series Contaminometer in Q1 2024
Oct 09, 2023 -
Gen3 Appoints John Barraclough as Head of Business Development Following Retirement of Nick Redgrave-Plumb
Sep 04, 2023 -
Gen3 to Showcase Cutting-Edge Test Solutions at Productronica India 2023
Sep 04, 2023 -
Gen3 to Exhibit at the 24th European Microelectronics & Packaging Conference
Aug 21, 2023 -
Unlock the Future of Electronics Manufacturing: Gen3 and Zestron Workshop
Jun 19, 2023 -
Gen3 Welcomes Daniel Ryland as New Area Technical Manager for the Southern Region
53 more news from Gen3 Systems »
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Gen3 Systems to Exhibit New SIR and CAF Systems with Ascentech LLC at the IPC APEX EXPO news release has been viewed 1074 times
