  • Gen3 Systems Installs Temperature & Humidity Test Chamber at Its UK Testing Facility
Aug 28, 2016
Temperature (& Humidity) Chamber (Platinous J Series).
Gen3 Systems Limited, a specialist British manufacturer and distributor, has installed a second chamber due to the increase in demand for its Surface Insulation Resistance (SIR) and Conductive Anodic Filament Monitoring (CAF) test services. The new Temperature (& Humidity) Chamber (Platinous J Series) takes Gen3’s in-house testing facility to the next level.
Quality assurance is extremely critical to the electronics manufacturing industry. During transportation or at the site of the end-user, electronics will see varying climates. With the temperature chamber, Gen3 can help manufacturers to determine if a product can withstand the rigors during its normal life span.
The temperature chamber tests the effects of extreme temperature changes as well as moisture or relative humidity on industrial products, materials, and electronic devices and components. The ability to test for temperature and humidity changes in-house allows Gen3 to even better serve its customers with tight manufacturing lead times.
The J Series Temperature Chamber has a working temperature range from -20 to +100°C (+150/180°C) and a humidity range from 20 to 98 percent rh. It can be used as a stand-alone test for environmental effects on test specimens, as preparation of test specimens for further physical tests or chemical tests, and as environmental conditions for conducting testing of specimens.
With the J Series Temperature Chamber’s new PID control of refrigeration capacity, the Smart Refrigerator & Dehumidifier System can control minutely both heating and cooling at minimal levels, thanks to the new N-instrumentation embedded in the chamber. An Ethernet (LAN) port is equipped as standard for simple connection to PC, Smartphone, Tablet, or other terminals. Monitoring chamber status, modification of test conditions, on-off operation, and other interaction with the chamber can be performed via web browser. The remote communication area can be expanded by connection to an intranet.
Gen3 Systems is a specialist manufacturer of test and measurement equipment used to help predict reliability of electronic circuits and systems in the field. In addition, the company designs and manufactures dip and spray coating process equipment in both in-line and bench-top formats. Gen3 is a specialist distributor for several leading equipment manufacturers including, ACE, Hirox, FineTech, MBTech, MEK, Optilia and, most recently, Global Distributor for Aprotec Instrumentation, Solder Paste Inspection (SPI) systems.
Gen3 Systems also provides training, equipment and expertise for manufacturers requiring assessment of their electronic products’ reliability. The company also operates a test service and assists with standards development via both the IPC and IEC. Gen3 Systems operates from premises near Farnborough Business Park, on the M3 corridor and just 30 minutes from London’s Heathrow Airport.
Jun 17, 2024 -
May 13, 2024 -
GEN3's Graham Naisbitt Speaks with Nolan Johnson on the Crucial Topic of Objective Evidence and the New IPC J-STD-001 Standard
Mar 11, 2024 -
GEN3 to Demo SIR Testing, Stencil Cleaning & More with Horizon Sales at APEX
Feb 05, 2024 -
GEN3 to Showcase Advanced Inspection and Testing Solutions at the Southern Manufacturing & Electronics Expo
Jan 15, 2024 -
Gen3 to Release Next Generation CM Series Contaminometer in Q1 2024
Oct 09, 2023 -
Gen3 Appoints John Barraclough as Head of Business Development Following Retirement of Nick Redgrave-Plumb
Sep 04, 2023 -
Gen3 to Showcase Cutting-Edge Test Solutions at Productronica India 2023
Sep 04, 2023 -
Gen3 to Exhibit at the 24th European Microelectronics & Packaging Conference
Aug 21, 2023 -
Unlock the Future of Electronics Manufacturing: Gen3 and Zestron Workshop
Jun 19, 2023 -
Gen3 Welcomes Daniel Ryland as New Area Technical Manager for the Southern Region
53 more news from Gen3 Systems »
Jun 28, 2024 -
Jun 26, 2024 -
Jun 25, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Gen3 Systems Installs Temperature & Humidity Test Chamber at Its UK Testing Facility news release has been viewed 990 times
