  • Gen3 Systems to Exhibit Its Cleaning & Contamination Systems with Ascentech at SMTAI
Aug 31, 2016
Gensonic Stencil Cleaning, system.
Gen3 Systems Limited, a specialist British manufacturer and distributor, will exhibit in Booth #219 with Ascentech, LLC at SMTA International, scheduled to take place Sept. 27-28, 2016 at the Donald Stephens Convention Center in Rosemont, IL.
The global award-winning Gensonic Stencil Cleaning, system will be displayed with a 24" stencil frame. The system uses a 40kHz on-contact ultrasonic transducer for high efficiency cleaning of stencil apertures. The Gensonic can be used either in conjunction with Gen3 stencil cleaning centres or is portable enough to be taken directly to the printer.
Gen3 also will display the award-winning contaminometerTM , in particular the CM22+ will be displayed. The CM+ features:
  • Complete testing within only 3 minutes
  • The entire tank volume is re-circulated 6 times every minute (CM33L up to 240 litres per minute)
  • Unique solid gold measuring cell, ballistic amplifier providing a test accuracy of <0.005mS/cm
  • Unique CURVE-FITTING Analysis algorithm (Merit of Fit)
  • Full regeneration in typically < 6 minutes
  • Smooth bubble-free circulation at all times
  • Accurate measurement even when the proportion of test solution to surface area under test are huge
  • Automatic temperature compensation
  • Measures in accordance with all international and MIL specifications old and new
  • New range of PCB/Component handling frames, with integrated draining system.
The CM Series comprises: CM11+, CM22+, CM33+, CM33L+, CM60 and CMBBT.
In addition to the above, Gen3 also manufactures conformal coating process equipment – bench-top and in-line systems, and SIR, CAF and solderability testing systems. The company also offers a range of test services. Gen3 distributes products for ACE, Finetech, Optilia, Vacunest, Stoelting, Hirox and MBTech..
Gen3 Systems is a specialist manufacturer of test and measurement equipment used to help predict reliability of electronic circuits and systems in the field. In addition, the company designs and manufactures dip and spray coating process equipment in both in-line and bench-top formats. Gen3 is a specialist distributor for several leading equipment manufacturers including, ACE, Hirox, FineTech, MBTech, MEK, Optilia and, most recently, Global Distributor for Aprotec Instrumentation, Solder Paste Inspection (SPI) systems.
Gen3 Systems also provides training, equipment and expertise for manufacturers requiring assessment of their electronic products’ reliability. The company also operates a test service and assists with standards development via both the IPC and IEC. Gen3 Systems operates from premises near Farnborough Business Park, on the M3 corridor and just 30 minutes from London’s Heathrow Airport. For more information about Gen3 Systems, visit www.gen3systems.com.
May 13, 2024 -
GEN3's Graham Naisbitt Speaks with Nolan Johnson on the Crucial Topic of Objective Evidence and the New IPC J-STD-001 Standard
Mar 11, 2024 -
GEN3 to Demo SIR Testing, Stencil Cleaning & More with Horizon Sales at APEX
Feb 05, 2024 -
GEN3 to Showcase Advanced Inspection and Testing Solutions at the Southern Manufacturing & Electronics Expo
Jan 15, 2024 -
Gen3 to Release Next Generation CM Series Contaminometer in Q1 2024
Oct 09, 2023 -
Gen3 Appoints John Barraclough as Head of Business Development Following Retirement of Nick Redgrave-Plumb
Sep 04, 2023 -
Gen3 to Showcase Cutting-Edge Test Solutions at Productronica India 2023
Sep 04, 2023 -
Gen3 to Exhibit at the 24th European Microelectronics & Packaging Conference
Aug 21, 2023 -
Unlock the Future of Electronics Manufacturing: Gen3 and Zestron Workshop
Jun 19, 2023 -
Gen3 Welcomes Daniel Ryland as New Area Technical Manager for the Southern Region
May 30, 2023 -
Gen3 Launches "The Printed Circuit Assembler's Guide to...™ Process Control" eBook in Collaboration with i-Connect007
52 more news from Gen3 Systems »
Jun 05, 2024 -
Jun 05, 2024 -
Jun 04, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Gen3 Systems to Exhibit Its Cleaning & Contamination Systems with Ascentech at SMTAI news release has been viewed 1139 times
Solder Paste Dispensing
