  • MIRTEC to Showcase Cutting-Edge 3D Technology Inspection Systems at 2026 APEX EXPO
Feb 23, 2026
MIRTEC, the ‘Global Leader in Inspection Technology’, is proud to announce its participation in APEX EXPO 2026. The premier event for the electronics manufacturing industry will be held from March 17-19, 2025, at the Anaheim Convention Center CA. Visitors can find MIRTEC at Booth #2800, where the company will showcase its full lineup of advanced 3D AOI and SPI inspection systems.
MIRTEC’s flagship Anti-Reflection Technology (ART) 3D AOI System is the world’s first 95MP Multi-Camera / Full HD Projection inspection platform. Equipped with five high resolution cameras and four Full HD digital projectors, the system delivers unprecedented accuracy for inspecting highly reflective objects such as solder joints—an area where conventional AOI systems have long struggled.
The breakthrough lies in ART’s innovative optical architecture. Conventional AOI solutions often rely on algorithms to fill in data lost due to specular reflections or blind spots caused by component structures. ART resolves these limitations by capturing 3D data from multiple directions, ensuring that solder joints are inspected entirely on the basis of actual measured data. Even when reflections or blind spots prevent the top-down camera from capturing accurate results, ART’s side cameras seamlessly fill in the gaps, enabling comprehensive inspection without compromise.
MIRTEC’s GENESYS-CC for conformal coating inspection AOI is configured with a high resolution camera, lens, and 10 phase coaxial color lighting system that includes three stages of UV lights. This allows the GENESYS-CC to provide more accurate and faster inspection compared to others. It also stands out from competing conformal coating inspection systems with three distinctive optical features. First, GENESYS-CC provides an option to overcome the challenges of bubble detection. By selecting the high-resolution 4lens, it is possible to detect bubbles as small as 60with exceptional precision. This advanced optional optical system ensures flawless bubble detection with unparalleled inspection accuracy. Second, the system incorporates three UV-enabled lighting stages, enabling compatibility with a wide variety of coating materials like acrylic, silicon and, etc. The last distinctive feature is the side camera for lateral coating inspection. The inclusion of a side camera allows for through inspection of side-coated areas, enhancing the overall inspection capabilities. In addition to these standout features, MIRTEC’s GENESYS-CC is capable of measuring coating thickness of most acrylic and silicon coating materials. Furthermore, the optional flipper conveyor applied inside the machine allows double-sided PCB inspection without the need of an external flipper.
MIRTEC will also display award-winning MV-6 OMNI 3D AOI System. It is configured with a 15MP High-Resolution CoaXPress main camera combined with an 18MP side camera, and MIRTEC’s exclusive 3D Digital Blue Moiré Projection Technology. Also, the MV-6 OMNI can support precise 3D inspection of parts up to 40㎜ in height by moving the Z-axis. Finally, the optional flipper conveyor applied inside the machine allows double-sided PCB inspection without the need of an external flipper.
MV-6 OMNI 3D AOI System will be configured with a specialized 3D laser scanner attachment, TAL 3D SCAN, the pre-inspection system before MV-6 OMNI. The TAL 3D SCAN can inspect up to 70㎜ parts in 3D, which is the tallest height range measurement on the market. Furthermore, this is possible without the need of Z-axis movement unlike the other 3D AOIs, where there is no slow-down of the inspection time. The TAL 3D SCAN does not interfere with inspection speed in any way. According to the in-house test results and calculation from MIRTEC, this innovative system promises about 30% improvement in productivity for THT-SMT mixed PC inspection. (※This number can increase further as there are taller component percentages within the PCB)
MIRTEC’s improved MV-3 OMNI Benchtop 3D AOI System is configured with the same hardware and software as MIRTEC’s in-line OMNI-VISION® 3D Inspection Systems providing 100% compatibility across MIRTEC’s entire 3D AOI product line. These systems feature our exclusive OMNI-VISION® 3D Inspection Technology which combines 15 MP CoaXPress Camera Technology with MIRTEC’s revolutionary Digital Tri-Frequency Moiré 3D system in a cost effective platform. MIRTEC’s 15 MP CoaXPress Vision System is a proprietary camera system designed and manufactured by MIRTEC for use with our complete product range of 3D inspection systems. MIRTEC’s Twelve (12) projection Digital Tri-Frequency Moiré Technology provides true 3D inspection to yield precise height measurement data used to detect lifted part and lifted lead defects as well as solder volume post reflow.
Upgraded MV-3 OMNI is capable of inspecting high and low-height parts mixed PCBs by expanding to top clearance of 70㎜ and bottom clearance of 100㎜. Improved inspection capability of bottom clearance allows inspection of tall parts. Also, this will bring customer satisfaction in both the automotive electronics industry and the defense industry. Furthermore, the safety features of upgraded MV-3 OMNI designed for the user convenience and safety have been strengthened even though they were already safe. Without a doubt, the MV-3 OMNI is the most technologically advanced Benchtop 3D AOI system in the world!
MIRTEC’s MS-11 3D SPI System features our exclusive 15MP or 25MP CoaXPress camera technology, providing enhanced image quality, superior accuracy, and incredibly fast inspection rates. The MS-11 3D SPI is also available with 4MP Camera Link option. It use dual projection shadow-free moiré phase shift imaging technology to inspect solder paste depositions on PCBs post screen print for insufficient/excessive solder, shape deformity, a shift of deposition, and bridging. All MIRTEC’s 3D SPI systems are IPC CFX compliant and feature upstream and downstream Closed-loop feedback. The new 'Quick Tracker' function is made available by connecting MIRTEC's 3D SPI to its 3D AOI system. This function allows users to check SPI inspection results with 3D images from linked AOI’s GUI.
MIRTEC’s Smart Factory Automation solution, ‘INTELLI-PRO AI’, is an AI based Software Suite specifically designed for the purpose of improving the performance and convenience of MIRTEC’s complete line of AOI machines. The INTELLI-PRO AI consists of a proprietary Deep Learning based Automatic Part Search and Teaching function, and AI based; Automatic Parameter Optimization, Character Recognition (OCR), Foreign Object Detection (FOD), Placement Inspection Algorithms and an Automatic Defect Type Classification function. The post-inspection stage is a process in which inspection results are reviewed and classified. When the AOI finds a defect, the PCB will be sent to an NG buffer. Upon review, an operator will be able to judge if the defect is real or a false call. Deep Learning Auto Defect Classification Tool, one of MIRTEC’s considerations for customers, can change that. This software will ‘suggest’ to the user whether the defect on a NG PCB is a real defect or a false call. However, as the software accumulates inspection data, the software will learn to identify real issues versus false calls. The predictions will become more accurate over time. Eventually, after approximately six months of learning, the software can then ‘judge’ the defect rather than ‘suggest’ to the user.
MIRTEC’s ongoing commitment to innovation has positioned the company as a trusted supplier of advanced inspection solutions for the electronics manufacturing industry. With a focus on high-tech sectors such as automotive, aerospace, and defense, MIRTEC continues to push the boundaries of the inspection technology.
Join MIRTEC at Booth #2800 at the APEX EXPO 2026 to experience why the company is recognized as one of the most dynamic and forward-thinking providers of inspection systems in the industry.
Feb 23, 2026 -
Europlacer to Showcase Production Integrity and Partnership at APEX EXPO 2026
Feb 02, 2026 -
Europlacer Puts Intelligent, Connected Production in the Smart Factory at productronica China
Jan 26, 2026 -
New White Paper Highlights How Shrinking Solder Powder Sizes Increase Cleaning Complexity in Advanced Packaging
Jan 19, 2026 -
Europlacer Americas Receives 12th Consecutive Service Excellence Award
Jan 15, 2026 -
Europlacer Puts Intelligent, Connected Production in the Spotlight at Southern Manufacturing
Nov 24, 2025 -
MIRTEC Receives Global Technology Award for ART 3D AOI System at productronica 2025
Nov 17, 2025 -
PANDA Robotics USA Recognized in 2025 TITAN Innovation Awards: Season 2 for Excellence in Robotic Technology
Nov 03, 2025 -
ZESTRON Hosts Webinar "La Pesadilla del Conformal Coating: Identifica y Evita Defectos"
Oct 27, 2025 -
Europlacer to Showcase Production Integrity and Partnership at Productronica 2025
Oct 20, 2025 -
ZESTRON to Showcase Analytical Services and Technical Center at SMTA International 2025
91 more news from 3M Electrical Solutions Division »
Feb 23, 2026 -
Libra Industries Appoints Mayur Mundra as Chief Financial Officer
Feb 23, 2026 -
Triple the Clean: PBT Works Showcases Three Closed-Loop Systems at APEX 2026
Feb 23, 2026 -
Weller Tools Brings the Full Soldering Workbench to Booth 3516 at APEX 2026
Feb 23, 2026 -
Sono-Tek to Debut SelectaFlux 3 and New Flux Monitoring Capabilities at 2026 APEX EXPO
Feb 23, 2026 -
Scienscope Brings Next-Gen Component Management and X-ray Innovations to APEX 2026
Feb 23, 2026 -
Horizon Sales Brings Test, Clean, and Automation Tech to the Forefront at APEX 2026
Feb 23, 2026 -
Nordson Electronics Solutions to exhibit innovations for conformal coating and selective soldering at APEX Expo 2026 booth # 1831.
Feb 23, 2026 -
Kurtz Ersa to Launch New Selective Soldering, Reflow, and Rework Technologies at APEX 2026, Booth 2113
Feb 23, 2026 -
Magnalytix to Bring Objective Evidence Ease and Reliability Knowledge to APEX 2026
Feb 23, 2026 -
Adaptsys and V-TEK Team Up at APEX to Rethink Tape-and-Reel Workflows
SMT Feeders
