  • AI Technology, Inc. (AIT) Releases COOL-PAD™ CPR (Conformal Pad) 7154: Second Generation (US Patent 6,496,373).
Mar 20, 2014
AI Technology, Inc. (AIT) announces COOL-PAD™ CPR 7154, which provides both compressibility and conformability with phase-change ability to achieve the best of thermal grease performance.
COOL-PAD™ CPR7154 is a new class of thermal interface material that dispenses like a thermal pad, but performs with characteristics like that of a grease or gel when device temperatures increase to above 45°C. COOL-PAD™ CPR7154 is optimized to accommodate large areas with different heights and gaps of less than 3-mil along its interfacing area.  It is filled with a modified oxide mixture and is electrically insulating at normal voltage. It is designed to have high compressibility as applied in comparison to traditional thermal pads.  Once the device temperature reaches 45°C, COOL-PAD™ CPR7154 will "melt-flow" to fill even the smallest of trapped air along the interface between the device and heat-sink or heat-spreader.
COOL-PAD™ CPR7154 is semi-tacky on both sides for optimum thermal transfer performance. COOL-PAD™ CPR7154 has high thermal conductivity and low Tg characteristics that impose minimum thermal stress on bonded parts during thermal cycling or shock testing.  While COOL-PAD™ has some intrinsic tack strength, it is not designed for bonding.  A mechanical fastener must be used to provide assembly integrity.
A mechanical fastener of 5 psi or more is recommended to provide intimate contact between the COOL-PAD™ and the interfacing surface.  Because COOL-PAD™ is compressible, it will fill in uneven height differentials and warps between the mating surfaces.  The ultimate performance of COOL-PAD™ is achieved after the first cycle of melt-flow phase-change at 45°C or automatically when the device heats up during operation or with externally applied heat if the device is not anticipated to reach 45°C .
COOL-PAD™ CPR7154 is designed for thermal interface applications to withstand the worst of temperature and moisture exposure in outdoor LED luminaire applications with modules from Philips, Cree, Bridgelux, etc. Of course, the same phase-change pad works great for CPU and GPU in Xbox360, Play Station, and other game consoles.   COOL-PAD™ CPR7154  is also ideal for CPU modules and graphic card interfaces in laptops and desktops such as Asus, Samsung, BenQ, Foxconn and other OEM.
Since pioneering the use of flexible epoxy technology for microelectronic packaging in 1985, AI Technology has been one of the leading forces in development and patented applications of advanced materials and adhesive solutions for electronic interconnection and packaging. AI Technology now has one of the highest reliability adhesives and underfills for die bonding for the largest dies, stack-chip packaging with dicing die-attach film (DDAF), flip-chip bonding and underfilling and high temperature die bonding for single and multiple-chip modules for applications beyond 230°C. The company continues to provide the best adhesive solution for component and substrate bonding for both military and commercial applications.
AIT’s thermal interface material solutions, including our patented phase-change thermal pads, thermal greases and gels and thermal adhesives have set many bench marks of performance and reliability for power semiconductors, modules, computers and communication electronics.
To submit an application analysis request: http://www.aitechnology.com/analysis/
Media Contact:  Amy Grossman, (609) 799-9388, agrossman@aitechnoloy.com
Aug 17, 2016 -
Temporary Bonding Adhesive for Thin Wafer Handling
Mar 20, 2015 -
AI Technology, Inc (AIT) Introduces 3D-TSV Ultra-Thin Wafer Processing Temporary Bonding Adhesive Film
Nov 07, 2014 -
AI Technology, Inc (AIT) To Attend and Present Paper at IWLPC. AIT also attending IPC/SMTA High-Reliability Cleaning and Conformal Coating Conference.
Oct 14, 2014 -
AI Technology, Inc (AIT) Develops Conformal Coatings to Protect Electronics in Extreme Environments
Sep 05, 2014 -
AI Technology, Inc (AIT) Develops Temporary Bonding Wax for Precision Wafer and Substrate Back-grinding and Thinning Applications
Jul 28, 2014 -
AI Technology (AIT) Introduces Novel High Temperature Large Area Underfill with Proven Stress Absorption
Jun 05, 2014 -
AI Technology, Inc. (AIT) Releases Cool-Gumpad™ (Thermal Interface Pad) CGP7156
May 07, 2014 -
AI Technology, Inc. (AIT) Releases Electrically and Thermally Conductive 20 Micron Wafer Level Die-Attach Film (DAF)
Apr 10, 2014 -
AI Technology, Inc. (AIT) Increases Manufacturing Capacity of Advanced 10 Micron Wafer Level Die-Attach Film (DAF)
Sep 13, 2024 -
RELIANCE 57C405-E
Sep 13, 2024 -
HMS ABC-PDP AB7000-B
Sep 13, 2024 -
Sep 13, 2024 -
Sep 13, 2024 -
YOKOGAWA S9400UK
Sep 13, 2024 -
Sep 13, 2024 -
Sep 13, 2024 -
ABB DTDX707A 61430001-WG
Sep 13, 2024 -
GE IC220STR001
Sep 13, 2024 -
AI Technology, Inc. (AIT) Releases COOL-PAD™ CPR (Conformal Pad) 7154: Second Generation (US Patent 6,496,373). news release has been viewed 1257 times
