  • Innodisk Announces Certified Storage Solutions for In-Vehicle Computing
Sep 22, 2014
Innodisk Certified Storage Solutions are perfect for In-Vehicle Computing Systems
Taipei, Taiwan – Innodisk, the service-driven flash provider, announces today a new line of SSDs and DRAM designed specifically for in-vehicle computing. These storage solutions stand up to the challenges posed by the extreme environments found in cars, buses, trains, ships, fleet vehicles, and military vehicles.
EMI Resistant
Innodisk is the first peripheral supplier to obtain the European E-Mark certification, and the only storage solution provider with multiple in-vehicle computing compliant standards for EMI resistance. There are multiple peripherals and electronic devices in any modern vehicle, each of which can create electromagnetic radiation that disturbs the function of other electronic components. Innodisk’s In-Vehicle SSDs are certified products that cause no electromagnetic interference. System reliability is ensured at the end application.
Power Protection
Power is no guarantee in a moving vehicle. Innodisk’s exclusive iCell and iData Guard are integrated firmware and hardware technologies that ensure data integrity even when power is not guaranteed. When power loss is detected, multiple on-board capacitors provide a power buffer to the SSD so that the last piece of data on the DRAM can be safely discharged to flash storage. At the same time, the data protection mechanism is activated to reject data commands from the host. This design can prevent incomplete data from being recorded and cause a bad block in the NAND flash.
Low Power Consumption
Innodisk’s In-Vehicle SSDs support “slumber” mode with a low power consumption design, which significantly reduces power usage by 50% when compared to that of normal “power saving” modes. Most storage devices save power by reducing transmission frequency of flash. However, Innodisk’s design puts the device to sleep, preventing power usage when idle. A convenient “wake up” function is implemented to return the device quickly to normal operation when needed.
Wide Operating Temperature
Innodisk’s In-Vehicle flash and DRAM products are compliant with RoHS standards and able to operate under a wide temperature range. They can cope with extreme temperature conditions, with functional temperature range between -40 to 85 degrees Celsius. In addition, the flash product’s built-in thermal sensor detects when the temperature of the device is too high and the control IC of the SSD will automatically adjust the transmitting frequency to ensure stable performance under extreme temperature.
Mil-Spec Tough
Innodisk’s In-Vehicle computing flash and DRAM products are compliant with the US military standard MIL-STD-810F/G, for shock and vibration. Ordinary DRAM interfaces with a standard SO-DIMM connector, but our rugged DRAM design integrates a customized mounting pad which makes the device less likely to be affected by vibrations, and ensures a strong connection at the gold contacts for more stable and reliable DRAM operation.
Conformal Coating
Through the use of conformal coatings, Innodisk is able to provide SSDs and DRAM that are resistant to moisture, dirt, dust, and harsh chemicals found in automotive and outdoor environments. The conformal coating is a non-conductive cover that is about 0.03-0.13 mm. It is compliant with MIL- I-46058C, and also acceptable by IPC-A-610 electronic component standards. Innodisk is proud to partner with industry leader HumiSeal for raw materials. The entire process takes place in a dustless facility to prevent other substances from contaminating the product during transportation.
ARM-compatible
In-Vehicle computers are often non-X86 architecture and Innodisk offers the non-mainstream 32-bit DRAM modules for in-vehicle computing. This specification is suitable for non-x86 systems, and it works well with ARM architecture commonly used for tablets and mobile devices.
Product Availability
Innodisk in-Vehicle SSDs come in CFast flash in 4GB to 128GB capacities, as well as MIL-spec and standard rugged 2.5" SATA III SSDs up to 512GB capacity.
Innodisk In-Vehicle DRAM includes DDR2 and DDR3 SODIMMs in a variety of frequencies. Besides unbuffered wide-temperature DRAM, 32-bit ARM Compatible DRAM and registered Mini R-DIMM DRAM is available. All Innodisk In-Vehicle DRAM have the options of adopting conformal coatings to ensure optimal performance in extreme environments.
InnoTrans
Innodisk will be showcasing its In-Vehicle Storage Solutions at the International Trade Fair for Transportation Technology, InnoTrans, September 23-26 in Berlin, Germany . Innodisk will be at Hall 4, Booth 220 of Messe Berlin.
About Innodisk
Innodisk is a service driven provider of flash memory and DRAM products for the industrial and enterprise applications. With satisfied customers across the embedded, aerospace and defense, cloud storage markets and more, we have set ourselves apart with a commitment to dependable products and unparalleled service. This has resulted in products including embedded peripherals designed to supplement existing industrial solutions and high IOPS flash arrays for industrial and enterprise applications. The expanded business lines are leading our next step in being a comprehensive solution and service provider in industrial storage industry. Founded in 2005 and headquartered in Taipei, Taiwan with engineering support and sales teams in China, Europe, Japan, and the United States, Innodisk is able to support clients globally. With abundant experience and an unrivaled knowledge of the memory industry, Innodisk develops products with excellent quality, remarkable performance, great cost-efficiency, and the highest reliability. For more information about Innodisk, please visit http://www.innodisk.com.
May 20, 2015 -
Innodisk Announces Ultra-Reliable DRAM-less SSDs with High IOPS for Embedded Applications
Mar 20, 2015 -
Innodisk Unveils DDR4 Memory for Industrial Applications on Upcoming Skylake Platform
Feb 06, 2015 -
Innodisk Gives Sneak Peek of New Industrial Flash Products at Embedded World 2015
Jan 07, 2015 -
Innodisk’s ServerDOM SSD Wins 2015 Taiwan Excellence Award
Dec 22, 2014 -
Innodisk Announces Mini-DIMM series DRAM with Very Low Profile height for Communications Applications
Nov 14, 2014 -
Innodisk Expands Embedded Peripheral Series with Communication Modules, for IoT and Embedded Applications.
Nov 05, 2014 -
Innodisk Showcasing Flash Storage Array at Cloud Computing Expo and Supercomputing '14
Oct 24, 2014 -
Innodisk Achieves ISO/TS 16949 Automotive Certification for its Solid State Drives
Aug 22, 2014 -
Innodisk Announces New High IOPS Industrial SSDs
Aug 04, 2014 -
Innodisk to Speak on Latest Industrial and Enterprise Flash Technologies at Flash Memory Summit 2014
4 more news from Innodisk Corporation »
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
May 29, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 28, 2024 -
May 27, 2024 -
May 27, 2024 -
May 27, 2024 -
Innodisk Announces Certified Storage Solutions for In-Vehicle Computing news release has been viewed 953 times
