  • Innodisk Announces Mini-DIMM series DRAM with Very Low Profile height for Communications Applications
Dec 22, 2014
Taipei, Taiwan – Innodisk, the service-driven flash provider, announces Very Low Profile(VLP) DRAM aimed at communications applications. These compact Mini-DIMM format memory modules are ACTA Compliant and a mere .70" tall, making them suitable for the most space-constrained blade servers, routers, telecommunications, and networking devices.
Ultra Low Profile
At just .70"(17.9mm) high, Innodisk's Mini-DIMM modules beat both the JEDEC VLP standard of .74" and the industry standard of .72". These ultra-low profile DIMMs not only fit easily into the most space constrained 1U blade servers and VLP-compatible embedded systems, their extra low profile means improved airflow and thermal performance. Even at this small size, the Mini-DIMM modules come up at capacities up to 8GB for higher memory densities.
ATCA Compliant
Innodisk's Mini-DIMMs are fully ATCA(Advanced Telecom Computing Architecture) Compliant, making them compatible with ATCA blade servers, switches, routers and other ATCA compliant communications equipment. Furthermore, the DIMMs are ARM and MIPS instruction set compatible, allowing them be used in a whole range of telecom system applications.
Enterprise Grade
With an in-house manufacturing and testing facility, Innodisk uses top-grade ICs in its Very Low Profile Memory. Each Mini-DIMM uses Enterprise-Grade chips for the best reliability, and goes through an 8-hour burn-in test, ensuring only the best quality DIMMs make it through.
Availability
Innodisk's Mini-DIMMs comes in capacities of 2, 4, and 8GB and speeds of 1066/1333/1600MHz DDR3. Both Registered and ECC memory modules are available for your mission critical application. Innodisks Mini-DIMMs are compatible with ARM and MIPS based systems common in telecommunications.
For product details, please visit: http://goo.gl/ZFA2lp
About Innodisk
Innodisk is a service driven provider of flash memory and DRAM products for the industrial and enterprise applications. With satisfied customers across the embedded, aerospace and defense, cloud storage markets and more, we have set ourselves apart with a commitment to dependable products and unparalleled service. This has resulted in products including embedded peripherals designed to supplement existing industrial solutions and high IOPS flash arrays for industrial and enterprise applications. The expanded business lines are leading our next step in being a comprehensive solution and service provider in industrial storage industry.
Founded in 2005 and headquartered in Taipei, Taiwan with engineering support and sales teams in China, Europe, Japan, and the United States, Innodisk is able to support clients globally. With abundant experience and an unrivaled knowledge of the memory industry, Innodisk develops products with excellent quality, remarkable performance, great cost-efficiency, and the highest reliability. For more information about Innodisk, please visit http://www.innodisk.com.
May 20, 2015 -
Innodisk Announces Ultra-Reliable DRAM-less SSDs with High IOPS for Embedded Applications
Mar 20, 2015 -
Innodisk Unveils DDR4 Memory for Industrial Applications on Upcoming Skylake Platform
Feb 06, 2015 -
Innodisk Gives Sneak Peek of New Industrial Flash Products at Embedded World 2015
Jan 07, 2015 -
Innodisk’s ServerDOM SSD Wins 2015 Taiwan Excellence Award
Nov 14, 2014 -
Innodisk Expands Embedded Peripheral Series with Communication Modules, for IoT and Embedded Applications.
Nov 05, 2014 -
Innodisk Showcasing Flash Storage Array at Cloud Computing Expo and Supercomputing '14
Oct 24, 2014 -
Innodisk Achieves ISO/TS 16949 Automotive Certification for its Solid State Drives
Sep 22, 2014 -
Innodisk Announces Certified Storage Solutions for In-Vehicle Computing
Aug 22, 2014 -
Innodisk Announces New High IOPS Industrial SSDs
Aug 04, 2014 -
Innodisk to Speak on Latest Industrial and Enterprise Flash Technologies at Flash Memory Summit 2014
4 more news from Innodisk Corporation »
Jul 16, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Innodisk Announces Mini-DIMM series DRAM with Very Low Profile height for Communications Applications news release has been viewed 871 times
