  • TG-1000 Hotbar Bonding System for Small Displays and Wearable Products
May 26, 2017
Toddco3 TG-1000-24 Hotbar Bonding System with Motorized Rotary Table
Toddco3 has released a new member of the TG-1000 Hotbar Bonder series that incorporates a servo-driven rotary table for higher volume production of small displays, sensors or other small products that include flexible circuits.
TG-1000-24 includes a precision servo-driven rotary table which allows multiple positions to be programmed into a process sequence. This feature allows operators to load/unload parts during an ACF bonding or soldering cycle which effectively increases through-put of single hotbar systems.
“Toddco3 prefers motorized rotary tables versus pneumatic for precise positioning of fine pitch parts. Servo-driven rotary tables are more consistent over time which results in higher yields for hotbar production cells” says David Bratty, Sr., Toddco3’s Vice President of Operations.
TG-1000-24 standard features include floor standing base frame, compact overhead system controls with touch-screen display for easy operator access, a variety of digital camera options for manual fine-pitch alignment, system software that provides intuitive user interface and saves bond profiles with programmed rotary table positions as a sequence file for a complete, computer controlled production process that can be easily selected.
TG-1000 series bonders incorporate a closed-loop, high temperature controller for precision temperature control of Toddco3’s ceramic hotbars or metal hotbars. The versatile system design provides a wide force range (5 – 600 N) with a servo-driven bond head for accurate, variable pressure control. Standard data logging feature saves actual versus commanded performance for selected bonds. Two front-panel auxiliary thermocouple inputs can also be displayed and logged for thermal analysis. Remote Network Communications Option provides wired Ethernet network access to all stored bond logs and process data.
For more information about the TG-1000-24 Hotbar Bonding System, please contact Toddco3 at info@toddco.com, www.toddco.com or call 1.619. 286.3326. News release contact is Debie Burford, dburford@toddco.com.
About Toddco3
Toddco3 manufactures factory automation equipment for the electronics industry using localized, high temperature, thermocompression to connect components. Based in the Greater San Diego, CA area; Toddco3 is a privately held Calif. partnership. For more information, please contact info@toddco.com, www.toddco.com or call 1.619.286.3326.
Aug 16, 2014 -
Toddco General, Inc. TG-1000 Hot Bar Bonding System for large displays and substrates
Jul 16, 2014 -
New G4C Ceramic Hot Bars (Thermodes)
Jul 16, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
TG-1000 Hotbar Bonding System for Small Displays and Wearable Products news release has been viewed 1215 times
