Wisman High Voltage Power Supply Co., Ltd was more than once successfully repaired many X-ray generators of the high performance WDXRF Axios which is manufactured by Holland Panalytical(formerly Holland Philips analytical).Axios’s X-ray generator Ouput Powe 2.4KW,4KW max, Current 160mA max,Voltage 60KV max. Axios-Poly’s X-ray generator Output Power 2.4KW,4KW max,Current 125mA max,Voltage 60KV max.
Wisman remind most Panalytical or other instrument users: Try to avoid power system sudden failure,Do routine maintenance and keep the instrument placed in laboratories and studios temperature and humidity,environment temperature initiative below 30 degrees, humidity below 80%, so as to avoid unnecessary fault, affecting production and experiment.
About Panalytical Axios X-ray generator Repair
Feb 26, 2015
