How Do You Store Components Long-Term?
Aug 02, 2017
The increasing requirement to store components for long periods of time creates challenges when accurately accounting for appropriate storage parameters. Whether you're protecting your ability to reproduce an identical product in the next year, safeguarding your inventory, or guaranteeing your price point, here are some considerations to make when storing your components long term.
Shelf life for components is determined by both the Bag Seal Date and the Humidity Indicator Card (HIC). 12 Months - 2 Years (max).
Moisture Control
Using a Dry Packs and/or Dry Atmosphere Cabinet to control moisture is essential for long-term storage of components. Low humidity can be maintained with dry air or Nitrogen and the ability to regain optimal moisture levels within 1 hour.
  • < 5% Relative Humidity (RH)
  • Nitrogen @ 25 ° Celsius +/-5
Temperature Control
Temperature is a critical factor when considering all aspects of preservation of components, especially oxidation & intermetallic formation.
12 Degress Celsius
The optimum parameters are subject to the details of each component as labeled on related packaging. Use the detailed information according to each component. As a general rule, however, in order to control for oxidation, corrosion, and intermetallic formation it is recommended to store components for no more than 2 years, at 12 ° Celsius, <5%RH.
Need more help?​
Contact us:
Southern Machinery | SMThelp.com
http://www.smthelp.com/full-factory-assessment/
info@smthelp.com
Aug 31, 2017 -
6 Key Technologies for LED Pick & Place Machines
Aug 08, 2017 -
How to Implement Splicing in Your SMT Factory | Increasing Productivity, Efficiency and Costs
Aug 03, 2017 -
How to Select LED Pick and Place Machine Nozzles
Aug 02, 2017 -
Surface Mount Assembly Classifications for EMS
Jul 18, 2017 -
One Company Makes it Easy to Shop SMT Equipment from China
Jun 18, 2017 -
China Quality Outpacing Major Brands
Jun 05, 2017 -
Competing in the Automotive Market Requires Automation
Jun 03, 2017 -
Announcing New CAD Files Library & Request
May 29, 2017 -
SMT Stencil Cleaning: A List of Questions to Ask When Considering a Stencil Cleaner
Dec 08, 2015 -
ONLINE SHOPPING FROM WWW.SMTHELP.COM
How Do You Store Components Long-Term? news release has been viewed 1191 times
SMT Machines china
