Eunil, a worldwide leader in factory automation as a manufacturer of SMT peripheral equipment, has released its latest in-line coating machine, the ECM-1100, as part of the Coating Master ECM Series.
The ECM-1100 is used to spray coating liquid on PCBs and mounted parts.
Printed circuit boards (PCBs) are the foundation for electronics in everyday products ranging from automotive and consumer electronics to communications and industrial and energy applications. Due to the evolution of these products, PCBs often are exposed to damaging environments, including moisture, dust, harsh chemicals, extreme thermal cycling and vibration. Coating will provide the needed protection.
The ECM-1100 in-line machine is ideal for:
Consistency – repeatable results
Increased productivity – high throughput, reduced labor cost
Improved material utilization – material savings
Closed fluid system
Improved quality – little to no masking
The most common uses for the coating are to inhibit leakage and short circuit due to humidity and contamination, to inhibit corrosion, to improve fatigue life of solder joints to leadless packages and to provide mechanical support for small parts to prevent damages due to mechanical shock and vibration.
For more information, contact Eunil Sales at sales@eunilam.com, call (619) 661-8275, or visit www.eunil-ha.com.
Eunil is a world-wide leader in the Factory Automation Industry as a manufacturer of SMD peripheral equipment. Recently, they have expanded the scope of the business to include the Semiconductor and Automotive industries. Eunil H.A., Americas, Inc. is proud to provide the best customer service in the industry, and ensure superior quality throughout their entire product line. Eunil also designs and builds custom equipment for their clients.
