New Generation of Thermal Solutions G4
Apr 16, 2019
Thermal Forcing systems for Quick, Accurate thermal IC/sensor cycle test
https://mechanical-devices.com/
Mechanical Devices is proud to introduce a new generation of testing control units to test IC devices over temperature.
Improved technology has resulted in a breakthrough in the fabrication of new generation G4 units with significant advantages over the previous generation. The machines that rely on this innovative technology provide greater cooling power, energy-saving, quiet at work, emit less heat and have a longer life span.
With the Power Plus G4, the Silicon temperature of the high-power device can be maintained low during test running. The overshooting and recovery time are also remain low at high spikes during the test. The Power Plus cooling power is -44C@600W; -55C@400W; The temperature range is between -75C and +200C. The wide temperature range enables cooling also low to mid power devices Tj with big thermal leakage to -40C or -50C.
May 13, 2016 -
New Era in Testing DUT over Temperature
May 13, 2016 -
Mar 14, 2016 -
Thermal Control Units for IC Testing
New Generation of Thermal Solutions G4 news release has been viewed 852 times
