Automotive Ethernet Tester for Highly-automated Testing
Feb 10, 2020
The Automotive Ethernet Tester (AET) is a highly-automated test system for TC8 switching and AVB/TSN tests
The Automotive Ethernet Tester generates different traffic and speed grades and records them
Universal Test System by RUETZ SYSTEM SOLUTIONS for TC8 Switching and AVB/TSN Standards
RUETZ SYSTEM SOLUTIONS - experts in automotive data communications - presents the new Automotive Ethernet Tester (AET), a highly-automated test system for OPEN ALLIANCE TC8 switching and AVB/TSN tests at the component level. "The Automotive Ethernet Tester is the consistent further development of our own test platform to equip vehicle manufacturers and suppliers with the best possible test setup," explained Wolfgang Malek, General Manager and Co-founder of RUETZ SYSTEM SOLUTIONS. "Whereas our well-proven Ethernet Live Monitor purely serves the intelligent and efficient error analysis of Ethernet data traffic, the Automotive Ethernet Tester generates different traffic and speed grades and records them, including the appropriate capture device." The test suites contain different test cases as the basis for the respective test scopes. Currently available are test suites for OPEN ALLIANCE TC8 switching, Automotive gPTP, 1722, and QAV. Test suites for QBV and other TSN functions are under development.
Universal, Highly-automated, Comprehensive
The test cases are script-based and parameterized prior to a test run via a single configuration file that contains all relevant properties of the device under test (DUT). The DUT and the test cases can be simply configured via easy-to-understand application interfaces. Users can easily select the individual test cases from a constantly growing database and assemble them into a new test run by drag-and-drop. The AET automatically saves the recorded data in a predefined folder structure. In addition, the test system includes an infrastructure for the complete recording of sent and received data. RUETZ SYSTEM SOLUTIONS provides an additional AET analyzer tool for analysis. It accesses the file structure and generates a result log from the recorded data. By separating the test and analysis systems, both systems can be used productively and efficiently in parallel.
The Automotive Ethernet Tester consists of a 19-inch test rack with control and analysis software. A PC control unit regulates the test system. Depending on the implementation, the test platform can contain up to 15 Ethernet ports (100BASE-T1, 1000BASE-T1), each of which can simulate and evaluate specific test scenarios. The test platform provides a display and PPS output for precise evaluation of the gPTP synchronization, as well as a display for the port status. It also controls the power supply for the DUT.
RUETZ SYSTEM SOLUTIONS will present the Automotive Ethernet Tester for the first time at booth 3C at the Automotive Ethernet Congress from February 12 to 13, 2020 in Munich, Germany. In his presentation, "AVB/TSN Testing Strategy from Semiconductor up to ECU and System Level,” on 13 February at 10:00 a.m., Martin Heinzinger from RUETZ SYSTEM SOLUTIONS will explain another test system.
Feb 22, 2018 -
Data Logging: Intelligently and Efficiently
Apr 20, 2016 -
MTCM for MOST150 Coax Physical Layer Testing
Aug 29, 2024 -
FOXBORO P0916NG
Aug 29, 2024 -
FOXBORO FBM203 P0914SV
Aug 29, 2024 -
FOXBORO IPM2-P0904HA
Aug 29, 2024 -
FOXBORO RH916DB
Aug 29, 2024 -
FOXBORO RH924YF
Aug 29, 2024 -
FOXBORO FBM218
Aug 29, 2024 -
FOXBORO CP60 P0961FR
Aug 29, 2024 -
FOXBORO P0914XB
Aug 29, 2024 -
FOXBORO FBM205 P0914XG
Aug 29, 2024 -
FOXBORO FBM4/39/44 P0500RY
Automotive Ethernet Tester for Highly-automated Testing news release has been viewed 965 times
