What is SMT and where to by SMT spare parts
Aug 17, 2017
What is SMT and where to by SMT spare parts.
Surface-mount technology (SMT) is a method for producing electronic circuits in which the components are mounted or placed directly onto the surface of printed circuit boards (PCBs). An electronic device so made is called a surface-mount device (SMD). In the industry it has largely replaced the through-hole technology construction method of fitting components with wire leads into holes in the circuit board. Both technologies can be used on the same board, with the through-hole technology used for components not suitable for surface mounting such as large transformers and heat-sinked power semiconductors.
An SMT component is usually smaller than its through-hole counterpart because it has either smaller leads or no leads at all. It may have short pins or leads of various styles, flat contacts, a matrix of solder balls (BGAs), or terminations on the body of the component
Because "surface-mount" refers to a methodology of manufacturing, there are different terms used when referring to the different aspect of the method, which distinguishes for example the components, technique, and machines used in manufacturing. These terms are listed in the following table:
SMp term
Expanded form
SMD
Surface-mount devices (active, passive and electromechanical components)
SMT
Surface-mount technology (assembling and mounting technology)
SMA
Surface-mount assembly (module assembled with SMT)
SMC
Surface-mount components (components for SMT)
SMP
Surface-mount packages (SMD case forms)
SME
Surface-mount equipment (SMT assembling machines
SMTPLAZA mainly specialize in offering spare parts and accessorise for assembling and mounting machines, we called pick and place machine,auto-insertion equiments for brands, such as Fuji,Yamaha,Panasonic,Juki,Siemens Siplace,Samsung,Uniersal.
In SMTPLAZA you will source any parts and spares for your surface mount machines, with competitive price and satisfation warranty.
What we support to your assembly pick and place machine, and auto-insertion machines? We supply smt nozzles, it another name called smt pick and place nozzles ; SMT feeders(pick and place feeders),smt motors,usual it called servo motor, AC motor,smt vavle, there are KOGANER vavle, SMC vavle are the most popular using; smt cylinder, its for Koganer cylinder and smc cylider are the hot sell brands.
Anyway, you will source good baby from our warehous which stock thousands of smt spare parts.
Aug 09, 2024 -
What is SMT and where to by SMT spare parts news release has been viewed 1088 times
SMT Machines china
