KDPOF Provides Optical Connectivity for Smart Antenna Modules
Oct 12, 2017
KDPOF provides optical connectivity for Smart Antenna Modules
KDPOF – leading supplier for automotive gigabit connectivity over POF (Plastic Optical Fiber) – now provide their optical connectivity technology for Integrated Smart Antenna (ISA) Modules. An ISA consists of several antennas for signal reception, an Antenna Hub, and an Ethernet connection to the consumers of the antenna signals such as a radio device. If each of the several antennas in a car is routed to its respective ECU with its own cable, soon the complexity will be unacceptable. The Antenna Hub routes all signals from each antenna to an Ethernet network connected to all receptors of the signals. Gigabit Ethernet over POF (GEPOF) is ideally suited for the Ethernet connection due to its natural EMC-free property. "If the roof is not metallic, or has openings, in conventional systems an immense amount of energy is radiated by the coaxial cable that is coupled back into the ISA. This seriously degrades the ISA performance," explained Carlos Pardo, CEO and Co-founder of KDPOF. "Replacing the coaxial cable with POF completely solves this issue." KDPOF will present their GEPOF technology at IEEE-SA Ethernet & IP @ Automotive Technology Day on October 31 to November 2, 2017 in San Jose, California, United States.
EMC for Gigabit Connectivity
The EMC problem-free link also allows simple re-positioning of the antenna module. Another advantage of optical connectivity for Smart Antenna Modules is the easy integration with current 100 Mbps designs thanks to the host bus of the GEPOF transceiver being “Ethernet compliant” (SGMII/RGMII). Furthermore, the data link will aggregate various packets such as LTE-A, Wifi, V2x, etc. Last but certainly not least, with the current 100 Mbps BroadReach or 150 Mbps MOST not being sufficient, a 1 Gbps Ethernet link is needed. Going one Gigabit and beyond, GEPOF is futureproof.
KDPOF just announced the sampling of the first automotive grade Gigabit Ethernet POF transceiver KD1053. The KD1053 complies with the new IEEE standard amendment Std 802.3bv™ for Gigabit Ethernet over POF. It fully meets the requirements of carmakers by providing high connectivity with a flexible digital host interface, low latency, low jitter, and low linking time.
Apr 26, 2024 -
KDPOF Collaborates with Hinge Technology
Oct 04, 2023 -
TRUMPF and KDPOF showcase first 980nm automotive multi-gigabit interconnect system
Jun 28, 2023 -
ICs Made in Spain by KDPOF
Jun 07, 2023 -
KDPOF Celebrates IEEE 802.3cz-2023 Standard for Automotive Multi-gigabit Ethernet over Fiber Optics
Mar 08, 2023 -
KDPOF Endorses IEEE 802.3cz Standard Entering the Finishing Straight of Final Release
Mar 01, 2023 -
Automotive: KDPOF and Würth Elektronik Cooperate for Optical Multi-gigabit Ethernet
Nov 07, 2022 -
First Optical Automotive Ethernet Transmitter Test Demo Displays Proof of Concept for Multi-gigabit Data Connectivity
Sep 26, 2022 -
Automotive Gigabit Ethernet Switch EVB9351-AUT-SW-NXP with Optical Ports
Sep 07, 2022 -
TRUMPF and KDPOF Become Strategic Partners for Automotive Data Communications
Jul 27, 2022 -
KDPOF Designs First Optical 1000BASE-RH SFP Module for Automotive Ethernet
20 more news from KDPOF »
May 23, 2024 -
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
KDPOF Provides Optical Connectivity for Smart Antenna Modules news release has been viewed 1644 times
Cost-effective Conformal Coating Machine
