KDPOF Enables Seamless Optical Networks Integration
Feb 22, 2018
KDPOF provides a complete POF solution to be seamlessly integrated into the harness of the vehicle.
KDPOF – leading supplier for automotive gigabit transceivers over POF (Plastic Optical Fiber) – is delighted to present a complete POF solution to be seamlessly integrated into the wire harness of the vehicle. At the International Congress Automotive Wire Harness on March 13 and 14, 2018 in Ludwigsburg, Germany, KDPOF will display innovative gigabit POF solutions in partnership with leading wire harness suppliers such as TE and others. "POF cables are very reliable: they can withstand harsh environments and tolerate conditions such as routing across the engine compartment with temperatures as high as 105°C and down to –40°C," stated Carlos Pardo, CEO and Co-founder of KDPOF. "As an optical fiber with a large core, POF is able to withstand vibrations and misalignments much better than other optical or copper alternatives such as glass optical fiber (GOF), coax, and STP."
Well-established engineering collaboration between key leading optoelectronic, connector, and wire harness vendors worldwide ensures a well-supplied and competitive market for all the components needed in the system: Physical Layer (PHY), Fiber Optic Transceiver (FOT), fiber cable, and connectors. All these companies, such as Broadcom (formerly Avago), Hamamatsu, KDPOF, TE, and others, as well as the IEEE and ISO, are ready for the market opportunities that the new gigabit POF technology has opened.
Easy Handling and High Robustness
As a plastic, wide diameter fiber, POF is cheap to manufacture and install. It does not require any sophisticated equipment or professional qualification, and harness manufacturing processes do not need to be changed. Installation is just easy plug and play. Winding and clamping is similar to copper cables. Their good bending performance starts at a radius of 10 mm. Gigabit transmission distances of up to 40 meters are possible without in-line connectors, or 15 meters with up to 4 in-liners. Further, POF allows fast dynamic bending, tight bending, and dark liquid immersion in addition to delivering low noise and robustness regarding incoupling of electromagnetic fields.
Apr 26, 2024 -
KDPOF Collaborates with Hinge Technology
Oct 04, 2023 -
TRUMPF and KDPOF showcase first 980nm automotive multi-gigabit interconnect system
Jun 28, 2023 -
ICs Made in Spain by KDPOF
Jun 07, 2023 -
KDPOF Celebrates IEEE 802.3cz-2023 Standard for Automotive Multi-gigabit Ethernet over Fiber Optics
Mar 08, 2023 -
KDPOF Endorses IEEE 802.3cz Standard Entering the Finishing Straight of Final Release
Mar 01, 2023 -
Automotive: KDPOF and Würth Elektronik Cooperate for Optical Multi-gigabit Ethernet
Nov 07, 2022 -
First Optical Automotive Ethernet Transmitter Test Demo Displays Proof of Concept for Multi-gigabit Data Connectivity
Sep 26, 2022 -
Automotive Gigabit Ethernet Switch EVB9351-AUT-SW-NXP with Optical Ports
Sep 07, 2022 -
TRUMPF and KDPOF Become Strategic Partners for Automotive Data Communications
21 more news from KD »
Oct 15, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
KDPOF Enables Seamless Optical Networks Integration news release has been viewed 976 times
SMT Spare Parts and Feeders
SMT Feeders
