KDPOF Demos First 25 Gb/s Automotive-grade Optical Network
Jan 15, 2020
KDPOF demos first 25 Gb/s Automotive-grade Optical Multi-Gigabit Ethernet (Copyright: Getty Images)
Optical Multi-Gigabit Ethernet – on the Verge of Standardization and Implementation
KDPOF – leading supplier for gigabit transceivers over POF (Plastic Optical Fiber) – will proudly display the world’s first demonstration of an automotive-grade optical transmission system with 25 gigabits per second at the Automotive Ethernet Congress from February 12 to 13, 2020 in Munich, Germany. In his presentation, “Optical Multi-Gigabit Ethernet – on the Verge of Standardization and Implementation,” on February 13 at 14:30, Carlos Pardo, CEO and Co-founder of KDPOF, will show details on the process for the new standard for multi-gigabit in automotive. It will enhance the existing 10GBASE-SR, which is the current standard by IEEE, to establish a communications channel in optical fiber at 10 Gb/s. “With technological leaps such as electrical vehicles, automated driving, and V2X interconnection rushing through, automotive applications, utilization, and safety requirements are boosting the necessary network speed tremendously,” explained Carlos Pardo. “Consequently, in-vehicle networks are on the brink of speeds from one to multiple gigabits per second.”
IEEE 802.3 Automotive Optical Multi-Gigabit Standard
With the approval of the IEEE 802.3 working group, a team of individuals affiliated with more than 15 key carmakers and components suppliers, including KDPOF, has started the standardization of an IEEE 802.3 Automotive Optical Multi-Gigabit Standard with strong support from the industry. The working group headed by Carlos Pardo (KDPOF) kicked off last summer. The first prototypes are projected by the end of 2021. The study group will evaluate the creation of an IEEE Ethernet standard for the automotive industry, with speeds starting at 2.5 Gb/s and going up to 25 or 50 Gb/s.
The key advantages of the optical solution for specific applications using multi-gigabit speeds with in-vehicle connectivity are, among others, Electromagnetic Compatibility (EMC) thanks to the inherent galvanic isolation, low weight, and low cost. Relevant use cases from different carmakers in Europe and the USA incorporate the comprehensive features and benefits of the optical network technology. Use cases include the interconnectivity of telematics control modules, redundant and safe backbones for autonomous driving architectures, and advanced driver assist system (ADAS) sensors.
Key leading optoelectronic, connector, and wire harness vendors worldwide are prepared and already provide a well-supplied and competitive market with all the new components needed for multi-gigabit in the car: Physical Layer (PHY), Fiber Optic Transceiver (FOT), fibers, connectors, and light sources. The technology will be scalable in order to enable even higher data rates such as 50 and 100 Gbps in the future. By combining optimization in all areas of the new standard, the right balance of complexity and cost among all parts (CMOS IC, VCSEL, PD, ferrules, sleeves, cable, in-line connection technology, optics, and lenses, etc.) can be achieved in order to deliver the lowest cost, most reliable, and highly scalable solution to the automotive market.
Apr 26, 2024 -
KDPOF Collaborates with Hinge Technology
Oct 04, 2023 -
TRUMPF and KDPOF showcase first 980nm automotive multi-gigabit interconnect system
Jun 28, 2023 -
ICs Made in Spain by KDPOF
Jun 07, 2023 -
KDPOF Celebrates IEEE 802.3cz-2023 Standard for Automotive Multi-gigabit Ethernet over Fiber Optics
Mar 08, 2023 -
KDPOF Endorses IEEE 802.3cz Standard Entering the Finishing Straight of Final Release
Mar 01, 2023 -
Automotive: KDPOF and Würth Elektronik Cooperate for Optical Multi-gigabit Ethernet
Nov 07, 2022 -
First Optical Automotive Ethernet Transmitter Test Demo Displays Proof of Concept for Multi-gigabit Data Connectivity
Sep 26, 2022 -
Automotive Gigabit Ethernet Switch EVB9351-AUT-SW-NXP with Optical Ports
Sep 07, 2022 -
TRUMPF and KDPOF Become Strategic Partners for Automotive Data Communications
21 more news from KD »
Jul 18, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
KDPOF Demos First 25 Gb/s Automotive-grade Optical Network news release has been viewed 809 times
