System Solution for Optical Communications in Vehicles
Sep 14, 2021
Demo setup of the optical multi-gigabit system solution from KDPOF for in-vehicle connectivity
KDPOF Presents Reliable and Cost-efficient Multi-gigabit Connectivity System at ELIV VDI Congress
Together with several industry leaders, KDPOF – leading supplier for gigabit connectivity over fiber optics – is working on an optical automotive multi-gigabit system that will fulfill the needs of future connected and automated vehicles. Instead of various port components, the new solution provides a single, complete package. “As the auto industry approaches the 50 Gb/s*m speed-length threshold, the move from copper to optical physical data transmission media is becoming mandatory,” stated Carlos Pardo, CEO and Co-founder of KDPOF. “Optical is the engineering-wise path for higher data rates.” The new connector systems are very small, lightweight and extremely inexpensive compared to the previous ones. With the comprehensive EVK9351AUT evaluation kit, automotive manufacturers and suppliers can already test the new configuration at 1 Gbit/s today. KDPOF thus supports easy project entry into optical gigabit connectivity for a secure Ethernet backbone and ADAS sensor connections in vehicles.
KDPOF will present their optical Multi-gigabit Ethernet Connectivity System at ELIV (Electronics In Vehicles) International VDI Congress on October 20 to 21, 2021 at stand 38 in Bonn, Germany, and online.
Off-the-shelf System Solution for In-vehicle Networking
The key advantages of the optical solution, among others, are superior Electromagnetic Compatibility (EMC) thanks to the inherent galvanic isolation, low weight, and low cost. The optical cables are absolutely reliable and at least as flexible as copper cables in the same bandwidth range. They allow fast, dynamic and tight bending as well as immersion in dark liquids. In addition, optical connectivity guarantees easy engineering for seamless implementation. The ecosystem already exists since the system leverages well-proven technologies, such as VCSELs (Vertical-cavity surface-emitting laser), multimode fibers and photodiodes already developed for the data centers industry. The technology will be scalable in order to enable even higher data rates, such as 50 and 100 Gb/s, in the future. Standardization processes are ongoing with IEEE 802.3 Automotive Ethernet and ISO PWI 24581 in progress. The robust and reliable system solution provided by KDPOF and industry leaders thus offers the future-proven path to high speeds.
Reliable, Robust and Cost-efficient
The proposed Multi-gigabit system supports Energy-Efficient Ethernet (EEE) tailored for automotive applications and wakes up in less than 100 ms. The target BER is better than 10-12 with ambient operating temp from -40ºC up to 105ºC (AEC-Q100 grade 2) in harsh automotive environments. High reliability (15 years operation, less than 10 FIT) and outstanding EMC compliance are also fulfilled. The technology in development is based on advanced digital signal processing, using high-speed DAC and ADC to implement all needed algorithms such as equalization or pre-coding. A new optical automotive IVN communication standard IEEE 802.3cz is currently in the task force phase and is targeting data rates of 2.5, 5, 10, 25, and 50 Gb/s. It is supported by several industry-leading companies. First engineering samples of the new automotive, single-chip, fully integrated Fiber Optic Transceiver package solution for 10 Gb/s will be available from KDPOF in fall 2022.
Apr 26, 2024 -
KDPOF Collaborates with Hinge Technology
Oct 04, 2023 -
TRUMPF and KDPOF showcase first 980nm automotive multi-gigabit interconnect system
Jun 28, 2023 -
ICs Made in Spain by KDPOF
Jun 07, 2023 -
KDPOF Celebrates IEEE 802.3cz-2023 Standard for Automotive Multi-gigabit Ethernet over Fiber Optics
Mar 08, 2023 -
KDPOF Endorses IEEE 802.3cz Standard Entering the Finishing Straight of Final Release
Mar 01, 2023 -
Automotive: KDPOF and Würth Elektronik Cooperate for Optical Multi-gigabit Ethernet
Nov 07, 2022 -
First Optical Automotive Ethernet Transmitter Test Demo Displays Proof of Concept for Multi-gigabit Data Connectivity
Sep 26, 2022 -
Automotive Gigabit Ethernet Switch EVB9351-AUT-SW-NXP with Optical Ports
Sep 07, 2022 -
TRUMPF and KDPOF Become Strategic Partners for Automotive Data Communications
21 more news from KD »
Nov 04, 2024 -
Good News, You can stop advertising on SMTnet Now
Nov 03, 2024 -
Oct 31, 2024 -
Enhanced AMR Software Released
Oct 31, 2024 -
PANDA Earns 7th Technology Award
Oct 30, 2024 -
ViTrox Showcases Groundbreaking Inspection Innovations at NEPCON Asia 2024
Oct 30, 2024 -
ViTrox Recognised for X-Ray Inspection Innovation at Global Technology Award 2024
Oct 29, 2024 -
XJTAG returns to Electronica 2024
Oct 28, 2024 -
Koh Young Earns Industry's Highest Customer Service Award - Again
Oct 28, 2024 -
North American PCB Industry Shipments Down 24.1 Percent in September
Oct 28, 2024 -
North American EMS Industry Shipments Up 10.3 Percent in September
System Solution for Optical Communications in Vehicles news release has been viewed 703 times
