  • Vitronics Soltec Introduces 3D-Printed Twin-Nozzle for ZEVA Point-to-Point Selective Soldering
Apr 14, 2020
ZEVAv selective soldering machine.
ITW EAE, the Electronic Assembly Equipment division of ITW is introducing an innovative new twin-nozzle developed by the Vitronics Soltec team for the ZEVA Selective Soldering System. The 3D-Twin-Nozzle™ has two nozzle diameters combined in one nozzle.
In point-to-point soldering multiple solder pots are typically used, with a different nozzle size for each pot. Fine-pitch components require a small nozzle while a larger nozzle is needed to solder double row components in a single drag and for larger components. In combination with rotation of the solder pot and tilting of the conveyor, the 3D-Twin-Nozzle™ makes it possible to solder a board with fine pitch and multiple row connectors without stopping for tooling changes. Software defines by recipe how the board is tilted and what the rotation angle of the solder pot should be using the selected nozzle.
This patent-pending design is only feasible with the design freedom of 3D metal printing technology. Integrated between the two nozzles is a Solder Drainage Conditioner (SDC) which blows hot nitrogen to prevent bridging. The nozzle is 3D printed out of stainless steel and is then hard chromized. This combination of metal and treatment prevents the nozzle from wear and makes it maintenance free. Different from wettable nozzles this nozzle doesn’t oxidize and has an infinitely long service life.
The 3D-Twin-Nozzle will be shown at IPC APEX Expo, February 4-6, 2020 in San Diego. Vitronics Soltec will also showcase the improved performance of the ZEVAm+ Selective Soldering system with live demonstrations every hour. The ZEVAm+ excels at fine pitch soldering with its ability to solder at an angle and the innovative SDC debridging tool.
ITW EAE, a division of Illinois Tool Works, Inc., is the global leader in process knowledge, services and manufacture of capital equipment used in the printed circuit board assembly and semiconductor industries. The group brings together the world’s leading brands of electronics assembly equipment: MPM Printers, Camalot Dispensers, Electrovert Cleaners and Soldering Solutions, Vitronics Soltec Soldering Solutions and Despatch Thermal Processing Technology. For more information visit www.itweae.com.
Nov 21, 2022 -
ITW EAE Introduces Auto Exit Wing Feature for Electrovert® Wave Soldering Machines
Aug 28, 2020 -
ITW EAE Wins Vision Awards for MPM Paste Management System and Electrovert Adjustable Wave
Apr 14, 2020 -
MPM Announces New EdgeLoc Board Clamping and Board Staging Options for Edison Printers
Apr 14, 2020 -
MPM Completes Next Generation Momentum II Printer Line with Introduction of BTB and 100 Models
Apr 14, 2020 -
Electrovert 'DwellFlex 4.0' Wave Solder Nozzle Wins New Product Innovation Award at IPC APEX 2020
Apr 14, 2020 -
Camalot Announces PCB Temperature Monitoring on Prodigy Dispenser to Ensure Underfill Process Stability
Apr 14, 2020 -
ITW EAE Receives Patent No. 10,434,537 for Camalot® Prodigy's™ Dynamic Dual Head™ Dispensing Technology
Apr 14, 2020 -
ITW EAE Wins Global Technology Award for the Camalot Prodigy's Dynamic Dual Head Dispensing Technology
Nov 05, 2019 -
MPM Introduces Next Generation Momentum II Printer
Oct 15, 2019 -
MPM to Present Technical Paper on Stencil Printing 0201 metric Apertures at Productronica
11 more news from ITW EAE »
Aug 09, 2024 -
Vitronics Soltec Introduces 3D-Printed Twin-Nozzle for ZEVA Point-to-Point Selective Soldering news release has been viewed 1039 times
