  • Clariant introduces pioneering Humitector™ Type 2 Non-Reversible Humidity Indicator Cards for SMD Dry Packing at Semicon Taiwan
Aug 21, 2018
Humitector™ Type 2 Non-Reversible Humidity Indictor Card and Desi Pak® Bentonite Desiccant for use in dry packing of moisture sensitive surface mount devices.
Shanghai, August 21, 2018 – Clariant, a world leader in specialty chemicals, delivers a new level of moisture-exposure assurance to surface mount suppliers and device manufacturers in the Far East, with the regional debut of the first Type 2 non-reversible humidity indicator card for dry packing – Humitector Type 2 – at Semicon Taiwan (Booth I-2823).
Clariant's new Humitector Type 2 Non-Reversible Humidity Indicator Cards contain a patent-pending non-reversible 60% humidity spot indicator which enables them to indicate whether dry packed surface mount devices (SMDs) have been exposed to high levels of moisture at any point during shipment or storage. This unique innovation offers a major step forward in preventing moisture-compromised surface mounts from entering production.
Until now, users of moisture sensitive, reflowable surface mount devices have had little choice in the humidity indicator cards required for use in protective packages governed by the J-STD-033 standard. Typical Type 1 cards offer only reversible indicators that reflect current (dry or humid) conditions at the precise time of checking.
The new Humitector Type 2 Non-Reversible Humidity Indicator cards provide verifiable color change accuracy and meet or exceed applicable European Chemical Bureau regulations. They have been approved for use by the Joint Electron Device Engineering Council (JEDEC) in the latest revisions to IPC/JEDEC J-STD-033 (J-STD-033D).
According to section 3.3.2.3 of J-STD-033D (April 2018), humidity indicator cards cannot be re-used in dry packing if the 60% spot indicates it has surpassed the threshold. The Humitector Type 2 non-reversible 60% indicator will show clearly if this threshold has been exceeded as the permanent colored spot will have migrated beyond its black circle.
"As originators of the color change humidity indicator card, we are very proud to lead the way with this advanced option for surface mount devices," said Menghwee Toh, Head of Clariant Cargo & Device Protection, Asia. "The 60% non-reversible indicator on these new cards makes it easy to see if the package contents have been exposed to high levels of moisture for a prolonged period of time. Importantly, they also avoid the use of substances of concern to the European Chemical Bureau and offer compliance with the recently updated dry packing standard for such goods. Indeed, the use of Type 2 HICs with a non-reversible 60% spot indicator is preferred by IPC/JEDEC standard J-STD-033D."
Visitors to Semicon Taiwan can explore the advantages of the Humitector Type 2 Non-Reversible Humidity Cards at the Clariant booth, I-2823. Clariant Cargo & Device Protection will also present Desi Pak® desiccant bags, a simple, dependable and economical solution for preventing moisture damage in enclosed packages such as dry packs for moisture sensitive surface mount devices. Placed together with our Humitector Type 2 inside a dry pack, Desi Pak will help protect against the harmful effects of moisture. Solutions are available through a global sales network with worldwide manufacturing sites in Brazil, Indonesia, Turkey, United States, and China.
For more information on the latest development, visit www.clariant.com/type-2-humidity-indicator-card.
™ TRADEMARK
Desi Pak® IS A TRADEMARK OF CLARIANT REGISTERED IN MANY COUNTRIES.
Mar 18, 2020 -
Clariant And Floreon Announce Collaboration To Expand High-Performance Biopolymer Applications To Additional Markets
Mar 05, 2020 -
Clariant Masterbatches introduces new colors for high temperature resins used in FAKRA connectors
Jan 13, 2020 -
Meet Clariant at IPC APEX EXPO for a one-to-one interview about the unique support for more sustainable electronics’ production and the J-STD-033D-preferred unique moisture-control combo for dry packe
Nov 15, 2019 -
Clariant turns the spotlight on 3D printed end use functional parts and new material for mobility and E&E trends at formnext 2019
Oct 22, 2019 -
Clariant introduces innovative halogen- and cobalt dichloride-free Type 2 Non-reversible Humidity Indicator Cards to ensure integrity of moisture sensitive electronic components
Jun 13, 2018 -
CLARIANT INTRODUCES HUMITECTOR™ TYPE 2 NON-REVERSIBLE HUMIDITY INDICATOR CARDS FOR SMD DRY PACKING
Oct 05, 2017 -
Clariant Whitepaper on Performance and Sustainability of Bentonite Clay Desiccants in Moisture Controlled Packaging
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Clariant introduces pioneering Humitector™ Type 2 Non-Reversible Humidity Indicator Cards for SMD Dry Packing at Semicon Taiwan news release has been viewed 1174 times
