Nowadays, with the rapid rise of science and technology, many fields are gradually mechanized. At this time, machine assembly is an indispensable step. In SMT production line, a pick and place machine is the most important and complex equipment. It can quickly and accurately paste components and bring good news to the complicated production process. So, what problems should we pay attention to when choosing a pick and place machine? The following suggestions are for your reference.
1. Pay attention to the accuracy of the mounter.
In the actual use process, everyone will have a higher requirement for the accuracy of parts. Because only when the work piece is done carefully, can it be favored by customers, and then make greater profits.
2. Pay attention to the running speed of the mounter.
The higher the operating speed, the higher the production efficiency. Only when it is more refined and guaranteed to be faster can it be called a good mounter.
3. Choose the patch method.
Nowadays, in order to make the machine run more precisely, the work piece becomes smaller and the circuit board becomes more complex. The number of components to be pasted is also increasing, which makes the patching process more and more difficult. Today's machines have three patch methods: manual, semi-automatic and automatic. Manual mounting is inefficient and error rate is high. This method is more suitable for repairing, which is in conflict with the concept and requirements of the current production line. Semi-automatic mounting uses vacuum to suck up the work piece and place it on the circuit board. It is superior to manual method in speed, but there are also errors due to the need for manual participation. Full-automatic mounting is the most common, not only in terms of speed far ahead of the first two, but also basically error-free, deeply loved by customers.
When choosing and purchasing, we can also consult relevant professionals with their expertise and experience, and then select according to their actual needs. We should consider all aspects and try our best to choose high-quality and low-cost products. We need to know that the quality of the SMD machine, to a large extent, determines whether the production is efficient. Therefore, I hope you can buy your favorite products.
