How the modern solder reflow oven works?
Oct 18, 2018
To successfully solder surface mount components to a circuit board, the heat should be transferred to the solder alloy paste until its temperature reaches a molten point (217°C for SAC305 lead free solder). The liquid alloy will merge with PCB copper pads and become a eutectic alloy mixture. A solid solder joint will be formed after it cools down below molten point.
There are three ways to transfer heat from heat source to heated objects.
  1. Conduction: Thermal conduction directly transmits through a substance when there is a difference of temperature between adjoining regions, without movement of the material. It occurs when two objects at different temperatures are in contact with one another other. Heat flows from the warmer to the cooler object until they are both at the same temperature.
  2. Radiation: Heat transfer through radiation takes place in form of electromagnetic waves mainly in the infrared region. Radiation is a method of heat transfer that does not rely upon any contact between the heat source and the heated object. The limitation of radiation is that black body will absorb more heat than white body.
  3. Convection: Heat convection is the transfer of heat from one place to another by the movement of fluids such as air or vapour gas. It is also a contactless method to transfer heat as well.
The modern solder reflow oven use the concepts of radiation and convection combined. Hheat is emitted by ceramic heat element with infrared radiation, but it doesn’t deliver it to a PCB directly. The heat will transfer to a heat regulator first to make heat output even. A convection fan will blow the hot air to an inner chamber. The target PCB can will get heat consistency in any spot.
http://www.flason-smt.com/new/How-the-modern-solder-reflow-oven-works.html
Dec 08, 2018 -
Dec 08, 2018 -
All about Semiconductor
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Ball Grid Array (BGA) Package
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Nov 18, 2024 -
IPC Celebrates National Apprenticeship Week with a Focus on Electronics Manufacturing Excellence
Nov 18, 2024 -
IPC Introduces First Standard for In-Mold Electronics
Nov 18, 2024 -
Disruptive Innovation and Generative AI Inventor, Kevin Surace, to Keynote IPC APEX EXPO 2025
Nov 18, 2024 -
Etek Europe Expands Partnership with ITW EAE to Represent Despatch Products in the UK and Ireland
Nov 18, 2024 -
Kurtz Ersa Honors Jean Verchere's 30 Years of Dedication as He Retires
Nov 18, 2024 -
KIC Launches Game-Changing TAS Software Platform to Address Emerging Thermal Process Challenges
Nov 18, 2024 -
Nordson Test & Inspection Receives Top Honor with Prime Step-by-Step Innovation Award for SQ3000M2 System
Nov 18, 2024 -
Scienscope's New Xspection 3120 Inspects Long PCBs
Nov 18, 2024 -
PARMI USA, INC. Appoints Juan Arango as Head of Sales and Business Development to Drive U.S. Market Growth
Nov 18, 2024 -
Naprotek Welcomes Aerospace and Defense Veteran to Board of Directors
How the modern solder reflow oven works? news release has been viewed 842 times
SMT Spare Parts and Feeders
