Advantages of Design for Manufacturability Rules
Oct 18, 2018
Design for Manufacturability (DFM) is an approach to fabricating and manufacturing printed circuit boards (PCBs) that reduces costs and makes PCB manufacturing a seamless process by applying a set of rules for the PCB designer to follow such that the typical PCB manufacturing processes, equipment, requirements and limitations are considered in the design.
Problems with PCB Designs That Do Not Consider Manufacturability
PCB Parts Procurement: Not all the specified PCB components and materials are available at the time a PCB order is placed. This frequently happens because there are many different types of PCBs such as flex, hi speed, radio frequency, hi temperature and RoHs, and all of them use different types of parts. In addition, component manufacturers may produce the same PCB parts with different specifications. It is important to confer with a PCB supplier to verify which specified parts are available, as well as what parts could be used as replacements. Without considering the procurement of PCB parts, lead times can be unnecessarily long. The optimal approach is to choose components that match the requirements of a PCB design and are readily available.
How Manufacturing Tolerances Affect Stack Up: Target impedance or stack up can vary due to the manufacturing tolerances of a specific PCB manufacturer. You should verify a target impedance with your PCB supplier because adjustments may need to be made to the PCB due to manufacturing tolerances. It is important to note that specially ordered materials can cause the total cost of manufacturing to increase with a corresponding increase in delivery times. It is always a good idea to discuss stack up concerns with your PCB supplier prior to finalizing your design.
Yield Issues: When printed circuit boards are designed with plane and signal layers that have the same specification, what usually results is an unnecessarily complex design that creates yield issues, which can increase the cost of PCB fabrication.
Data Files Without an IPC-356A Net List: When data files are exported to a PCB manufacturer, the data transmission can be corrupted or contain errors. To verify the PCB design contains no errors, an IPC-356A net list is required. This net list enables your supplier to check the Gerber files against the CAD database. If you do not have IPC-356A Net List, an important quality check cannot be conducted.
http://www.flason-smt.com/new/Advantages-of-Design-for-Manufacturability-Rules.html
Dec 08, 2018 -
Dec 08, 2018 -
All about Semiconductor
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Ball Grid Array (BGA) Package
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Advantages of Design for Manufacturability Rules news release has been viewed 753 times
