All about Semiconductor
Dec 08, 2018
http://www.flason-smt.com/new/All-about-Semiconductor.html
A semiconductor can conduct electricity under certain circumstances but not always. This property of a semiconductor makes it a good medium to use electricity in a controlled manner as and where required.
Conductance of a semiconductor depends on several factors such as current or voltage applied to a control electrode, or on the intensity of irradiation by infrared (IR), visible light, ultraviolet (UV), or X rays.
So, we can say that a semiconductor is a material that has electrical conductivity greater than an insulator but less than a conductor.
Examples of a semiconductor: Diodes, transistors, and many photovoltaic cells.
Facts about Semiconductor
As I mentioned above, a semiconductor has a dual property – conductor and insulator of electricity. This property of a semiconductor depends on impurities added to the semiconductor material (A pure semiconductor is called an “intrinsic” semiconductor). The impurities added to the semiconductor material to change its electrical property are called “dopants” and the process of adding impurities to the pure semiconductor material is called doping.
Types of Semiconductors
An N-type semiconductor is one that carries current in the form of negatively-charged electrons. This is very similar to conduction of current in a wire.
P-type semiconductor is one that carries current predominantly as electron deficiencies called holes. A hole has a positive electric charge. This charge is equal and opposite to the charge on an electron. These holes flow in the opposite direction of electrons.
Function of a Semiconductor
A semiconductor can help control flow of electricity. The basic function of a semiconductor device is to switch ON and OFF the flow or electricity as and when required. A semiconductor device can perform the function of a vacuum tube with hundreds of times its volume. A single integrated circuit (IC), such as a microprocessor chip, can do the work of a set of vacuum tubes.
Semiconductor Materials
There are several materials and elements used to make a semiconductor. The basic requirement of a semiconductor is that it should not be a very good conductor of electricity, nor should it be a very bad conductor of electricity. Its properties can be changed by adding or removing atoms / impurities.
Semiconductor materials include – antimony, arsenic, boron, carbon, germanium, gallium arsenide, selenium, silicon, silicon carbide, sulfur, tellurium, oxides of most metals.
Silicon is the most widely used semiconductor material.
Superconductor
Superconductor is an element, inter-metallic alloy, or a compound that conducts electricity without resistance below a certain temperature.
Once set in motion, electrical current will flow forever in a closed loop of a superconducting material.
Diode
A Diode is an electronic device that allows current to flow in one direction only. It is a a semiconductor that consists of a p-n junction. They are used most commonly to convert AC to DC, because they pass the positive part of the wave, and block the negative part of the AC signal, or, if they are reversed, they pass only the negative part and not the positive part.
A diode is the simplest possible semiconductor device, and is best device to learn and understand how a semiconductor works.
Transistor
transistor is a semiconductor device made of a solid piece of semiconductor material and is used to amplify and switch electronic signals. A Transistor can be active in only One Direction and can draw more or less current through its load resistor.
A transistor is another good example of a semiconductor device.
Semiconductor Manufacturing
Manufacturing semiconductors need expertise and experience. Chemicals to be used need to be pure and free from any impurity. The process of adding controlled impurities to a semiconductor is known as doping.
Here are the steps involved in manufacturing semiconductors:
1) Design / Mask Creation
2) Patterning
3) Wafer Fabrication
4) Device Formation / Device Insulation Layer Formation
5) Device Formation / Transistor Formation
6) Metallization
7) Assembly and Testing
Semiconductor Industry
The semiconductor industry is over $300 billion as of today and is expected to grow @ 13-15% annually. USA, South Korea, Japan, and European Union dominate the semiconductor industry and the business.
Top 10 Semiconductor Companies
Here is a list of top 10 semiconductor companies in the world:
  1. Intel Corporation: The world leader in silicon innovation, develops processor technologies and supports global initiatives.
  2. samsung Electronics: Semiconductors including DRAM, Flash, SRAM, Graphics Memory, MCP, Mask ROM, System LSI, TFT LCD Modules and more.
  3. Toshiba: Manufacturer and supplier of Semiconductor, Memory Storages Device, General-Purpose Logic IC, Transistors, Diode, Optical Semiconductor Device, Sensor, Radio-Frequency Device, Microcomputer, ASIC, ASSP, General-Purpose Linear IC, Power Supply IC, Transistor Array, Motor Driver, Operational Amplifier IC, Comparator IC, Op Amp.
  4. Texas Instruments: Designer and supplier of digital signal processors, discrete and integrated circuits, calculators, and digital light processing (DLP).
  5. STMicroelectronics: Offers System-on-Chip (SoC) and semiconductor solutions.
  6. Qualcomm: Leading provider of advanced semiconductor manufacturing technology.
  7. Hynix (Formerly Hyundai Electronics): Memory semiconductor supplier of dynamic random access memory (‘DRAM’) chips and flash memory chips.
  8. Renesas Technology: Semiconductor, microcomputers, logic and analog devices, discrete devices and memory products.
  9. AMD: Advanced Micro Devices: American multinational semiconductor company.
  10. Sony: Sony Semiconductor
Semiconductor Jobs
Because of rapid growth in the semiconductor industry, more and more semiconductor companies are coming up. There is great job and employment opportunity of electronics engineers in semiconductor industry.
Semiconductor jobs are available in following categories:
  • Electrical Engineering
  • Software Engineering/DSP
  • Technology Support
  • Sales/Marketing
  • Applications Engineering
  • Semiconductor Design
  • Materials Management
  • Fabrication/Production
  • Quality Assurance
  • Administrative
Just explore the “career”, “jobs” or “work with us” section of the websites of semiconductor companies and apply for the best suitable job.
Flason Electronic Co.,ltd provide a full smt assembly line solutions, including Lead free reflow oven, wave soldering machine, SMT pick and place machine, smt stencil printer, PCB conveyor manufacturer, PCB unloader, chip mounter, SMT AOI machine, SMT SPI machine, SMT X-Ray machine, SMT assembly line equipment, PCB production Equipment smt spare parts etc any kind SMT machines you may need, please contact us for more information: wechat whatsapp:008613691605420, Skype: flasonsmt, Email: sales@flason-smt.com
FAQ
1) This is the first time I use this kind of machine, is it easy to operate?
There is English manual or guide video that show you how to use machine.
If you still have any question, please contact us by e-mail / skype/ phone /trademanager online service.
2) If machine have any problem after I receive it, how can I do ?
Free parts send to you in machine warranty period.
If the part is less than 0.5KG, we pay the postage.
If it exceeds 0.5KG, you need to pay the postage.
3) MOQ ?
1 set machine, mixed order is also welcomed.
4) How can I buy this machine from you? ( Very easy and flexible !)
A. Consult us about this product on line or by e-mail.
B. Negotiate and confirm the final price , shipping , payment methods and other terms.
C. Send you the proforma invoice and confirm your order.
D. Make the payment according to the method put on proforma invoice.
E. We prepare for your order in terms of the proforma invoice after confirming your full payment.
And 100% quality check before shipping.
F.Send your order by air or by sea.
5)Why choose us ?
A. Gold supplier on Alibaba !
B. Trade assurance to US$54,000 !
C. Best price & Best shipping & Best service !
Contact information
PREVIOUS:Lead-Free (Pb-Free) Solder and CompositionNEXT:Top 10 Consumer Electronics Companies in the World
RELATED NEWS
  • Reflow oven provider-Flason
  • Lead-free processes propose new requirem
  • Nitrogen Protection Reflow Oven
  • Mixed process of SMT reflow oven
  • Solder Joint Reliability
CATEGORIES
  • Company News
  • Industry news
LATEST NEWS
  • How to Maintain a Reflow Oven?
  • How to optimize the reflow profile?
  • How the modern solder reflow oven works?
  • SMT Defect List
  • How to Prevent Solder Ball and Bridging Defects during the S
CONTACT US
Contact: Andrey
Phone: 13691605420
Tel: 0755-85225569
Add: Flason Industry park Shajing Town Baoan district shenzhen China 518104
SMT Reflow Oven Manufacturer Wave Soldering Mahchine Manufacturer Pick and Place Machine ManufacturerReflow Oven Manufacturer SMT Spare Parts LED Pick and Place Machine
Andrey: sales@flason-smt.com Wechat whatsapp:+86 13691605420
Keywords: Reflow Oven Manufacturer SMT Reflow Oven Manufacturer Wave Soldering Machine Manufacturer SMT Stencil Printer Manufacturer Pick and Place Machine Manufacturer SMT Inspection machine Manufacturer SMT Pick and Place machine Manufacturer SMT Peripheral Equipment Manufacturer SMT Spare Parts Manufacturer SMT Reflow oven SMT AOI Machine Manufacturer Chip Mounter Manufacturer Solder Paste Printers Manufacturer SMT Reflow Oven Manufacturer SMT Feeder Storage Cart Manufacturer Selective soldering machine Manufacturer SMT Nozzle Manufacturer Siemens Feeder SMT Feeder Manufacturer Wave Soldering Machine Manufacturer Lead Free Reflow Oven Manufacturer Selective Wave soldering machine LED strip Reflow Oven Manufacturer Wave Soldering Machine Manufacturer Automatic SMT Stencil Printer Juki RS-1 Pick and Place Machine SMT Peripheral Equipment Manufacturer China wave soldering machine manufacturer Small wave soldeirng machine
For More information,visit US: Reflow Oven Manufacturer or SMT Reflow Oven Manufacturer Wave Soldering Machine Manufacturer SMT Stencil Printer Manufacturer Pick and Place Machine Manufacturer SMT Inspection machine Manufacturer SMT Assembly Line Manufacturer SMT Peripheral Equipment Manufacturer SMT Spare Parts Manufacturer SMT Feeder Manufacturer SMT Nozzle Manufacturer SMT X Ray Machine Feeder storage cart Manufacturer SMT Reflow Oven Manufacturer manufacturer email us: sales@flason-smt.com
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Ball Grid Array (BGA) Package
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Dec 08, 2018 -
Top Silicon Wafer Manufacturing Companies in the World
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
All about Semiconductor news release has been viewed 1308 times
