5V,10A Synchronous Step-Down Silent Switcher 2_LTC3310S
Nov 13, 2018
News source:https://www.jotrin.com/technology/details/ADI_release_5V_10A_Synchronous_Step_Down_Silent_Switcher_LTC3310S
The LTC3310S features a Silent Switcher®2 architecture with integrated thermal loop bypass capacitors for high efficiency, small footprint applications (up to 5MHz) and excellent EMI performance.
Multiphase operation allows direct paralleling of multiple devices to provide higher output current. The LTC3310S's 2.25V to 5.5V input range supports a wide range of applications, including most intermediate bus voltages.
The integrated low on-resistance MOSFET provides up to 10A of continuous load current with minimal thermal derating.
The output voltage range of 0.5V to VIN is ideal for point-of-load applications such as high current/low voltage DSP/FPGA/GPU/ASIC reference designs.
5V, 10A low EMI monolithic synchronous buck converter_LTC3310S
The LTC3310S can be turned on within 35ns and can achieve high step-down ratio power supplies at high frequencies. The 100% duty cycle operation provides low dropout performance.
The overall reference voltage accuracy of the LTC3310S is between –40 degrees Celsius and 125 degrees Celsius. +/- 1% of the operating junction temperature range.
Other features include a power good signal when the output is in regulation, precision enable threshold, output overvoltage protection, thermal shutdown, a temperature monitor, clock synchronization, mode selection and output short circuit protection.
The LTC3310S is available in a thermally enhanced 18-lead 3mm x 3mm x 0.94mm LQFN package.
Class E and Class I device specifications operate over a range of operating junction temperatures from –40 degrees Celsius to 125 degrees Celsius.
Feb 15, 2019 -
Motion Sensor with Machine Learning-LSM6DSOX
Jan 02, 2019 -
Holiday notice for 2019 New Year-Happy new year to all
Dec 21, 2018 -
Promotional campaigns to celebrate the New Year and Christmas.
Nov 19, 2018 -
Jotrin Electronics attend the electronica in Munich Exhibition 2018
Oct 22, 2018 -
Vishay launches four new TMBS Trench MOS rectifiers
Oct 15, 2018 -
Western Digital Corp. Releases Industry’s First 96-Layer 3D NAND UFS 2.1 Embedded Flash Drive for High-End Smartphones
Sep 14, 2018 -
Jotrin Electronics Official Video Is Released
Sep 11, 2018 -
Holiday notice of Mid-Autumn Festival--happy mid-Autumn festival
Sep 04, 2018 -
AMD Radeon Pro V340 graphics card was introduced
Aug 21, 2018 -
Japanese technology giants fall ? Toshiba sells the core chip business
2 more news from Jotrin Electronics Limited »
Aug 09, 2024 -
5V,10A Synchronous Step-Down Silent Switcher 2_LTC3310S news release has been viewed 1081 times
