Advanced EMI Filters Keep Brush DC Motors “Low Cost”
Nov 12, 2019
Increasing EMC requirements are driving up the cost of low-priced, but noisy brush DC motors.
Monolithic EMI filters reverse the trend
Inexpensive and easy to operate, brush DC motors provide the ideal balance of performance at the right price in industries such as automotive, aerospace, medical, industrial, appliance, consumer and home automation products.  As a result, billions are manufactured annually worldwide, a figure that is expected to increase over the next 10 years.
However, increasing electromagnetic compatibility (EMC) requirements along with more crowded and “noisy” electronic environments are threatening to upset the balance by driving the cost of these low-end solutions to a level on par with more expensive brushless alternatives.
The issue is the electromagnetic interference (EMI) generated by the brushes as they rub the commutator – an inherent drawback of the design.  To counteract the noise generated, a combination of shielding and filtering components is required.
This not only drives up the cost, but many EMI/RF filtering solutions for brush DC motors on the market are not satisfactory to meet today’s higher EMC requirements.
“Many EMI filtering solutions do not filter out all forms of noise that are generated and many cannot handle higher DC currents without a corresponding escalation of the cost,” explains Christophe Cambrelin of Johanson Dielectrics, a company that manufactures a variety of multi-layer ceramic capacitors and EMI filters.
To address these concerns, companies such as Johanson Dielectrics are now offering more advanced EMI filtering solutions that increase costs of brush DC motors slightly, while meeting the evolving EMC requirements.
Noisy Electronics
When electronic devices receive strong electromagnetic waves, unwanted electric currents can be induced in the circuit and interfere with intended operations.  EMI can even cause physical damage in operational equipment.
Exacerbating the issue are increases in operating circuit frequency, noises of higher frequencies that expand the affected frequency range and the miniaturization of electronic devices that shrinks the distance between source and victim.
If that wasn’t enough, many electronic devices are more easily affected by noise, even with less energy, due to circuits today that operate at lower voltages.
As a result, industries such as the automotive sector are increasingly turning to brushless DC motors.  With Brushless DC Motors, the commutation is done electronically. Therefore there is significantly less noise generation (no noise generated by mechanical commutation), but the complexity and cost of implementation are increased.
So, given a choice, OEMs would prefer solutions that would maintain the relatively low price of the brush DC motors given the quantities involved.
EMI Filtering Solutions
EMI/RFI interference is either radiated or conducted in wide frequency range from several hundred hertz to several gigahertz.
Radiated noise occurs when voltage is applied at varying levels to the wiring.  To keep the radiations confined in the motor housing, several precautions should be taken by the manufacturers of Brush DC Motors. The most important is the material used for the motor housing, which should be metal, as well as a metal cap (not plastic) on top of it.  When the cap is made of plastic, the user needs to cover it with a metal shield (that may be a metallized PCB).
When EMI/RFI is conducted, the noise generated travels along the electrical power leads and is then radiated.  Shielding is ineffectual against conducted noise, so filtering is required with a separate device.
Traditional common mode filtering approaches include low pass filters comprised of capacitors that pass signals with a frequency lower than a selected cutoff frequency and attenuate signals with frequencies higher than the cutoff frequency.
Among the options for OEMs are 2-capacitor differential, 3-capacitor (one X-cap and 2 Y-caps), feed-through filters, common mode chokes, LC filters, or combinations of these.
To meet increasing EMC requirements, however, low cost solutions such as 2-capacitor differential filters are insufficient because unmatched capacitors generate a different filtering of each line, and therefore mode conversion (i.e. part of common-mode noise is transformed into differential-mode noise, and vice-versa).  Traditional 3-capacitor filters are adequate, provided the EMC requirements are only at relatively low frequencies (i.e. < 150MHz, such as AM/FM radios in automotive).
Although they provide good filtering performance, 3-capacitor filters are generally ineffective when filtering noise in telecom frequency bands.  Other solutions like feed-thru filters offer good rejection over a wide frequency band, but become expensive when the power line must carry a current of several Amps.
Additionally, feed-thru filters are single-ended devices, and therefore may introduce mode conversions (like 2-cap filters).
“Regardless of the noise generated, if a high DC current is required you will need a very large, expensive feed-through filter, which eliminates the brush DC motor as a low-cost solution,” says Cambrelin.
For brush DC motors, a possible alternative to low-pass filter is a common mode choke.
When a common-mode signal (same AC current) is going through each winding of the common-mode choke, the magnetic field coming from each winding adds up, and therefore the impedance increases significantly.  On the other hand, when a differential signal (opposite AC current) is going through each winding, the magnetic field coming from each winding will subtract to each other and therefore the impedance decreases significantly.
That is why Common mode chokes block common mode noise, but let a differential signal go through.  Similar to feed-thru filters, a bigger and more expensive common choke is required to be able to carry a significant current (i.e. more than 1A rms)
Despite the popularity of common mode chokes, a better alternative may be monolithic EMI filters.
Compared to common mode chokes, monolithic EMI filters provide significantly more RFI suppression in a substantially smaller package.  A monolithic EMI filter also rejects a much wider frequency band and is not affected by the amount of DC current required because it is mounted in shunt (between lines and ‘ground’).
EMI filters combine two balanced shunt capacitors in a single package, with mutual inductance cancellation and shielding effect.  These filters from Johanson Dielectrics utilize two separate electrical pathways within a single device attached to four external connections.
Like other EMI filters, monolithic EMI filters attenuate all energy above a specified cut-off frequency, only selecting to pass required signal energy while diverting unwanted noise to ‘ground’.
The key, however, is the very low inductance and matched impedance.  With monolithic EMI filters, the terminations connect internally to a common reference (shield) electrode within the device, and the plates are separated by the reference electrode.
Monolithic EMI filters can be effective from 50KHz to 6GHz and it filters both common-mode and differential mode noise.  The filter also has virtually no limit to the amount of DC current, because it is designed to work in parallel to motor and no DC current flows through it.
Pulse Width Modulated Signals
Regardless of the type of filter, an often-overlooked factor is the fact that many brush DC motors are controlled by Pulse Width Modulated (PWM) Signal, says Cambrelin.
With PWM signal, the voltage is switched on and off at a very fast rate between a few kilohertz (kHz) and tens of kHz.  The total power supplied is based on the time the switch is on compared to the off periods.  PWM signal is particularly suited for motors because the time constant of a motor is very long compared to the period of a PWM signal.  That is why the brush DC motor acts as if the average of the PWM signal was applied on the power leads.
“When you first test the motor in the lab the EMI filter may perform well, but everything changes when you apply a PWM signal on the power leads,” explains Cambrelin.  “You want to filter out the noise, but not [unintentionally] filter out the PWM signal.  If you don’t choose the right filter, the motor may not even start.”
This can be a problem for users that are not used to developing differential LC filters.
With monolithic EMI filters, there is no need for special skills in filtering: the response of the filter (i.e. rejection of common-mode noise versus frequency) is provided directly by the manufacturer.  For example, Johanson Dielectrics provides an on-line tool that simplifies the choice at https://s21plotter.johansondielectrics.com.
Cambrelin says Johanson Dielectrics is also working on an integrated solution for brush DC motors that will allow to mount the monolithic EMI filter directly on the housing without the need to manufacture a PCB.
“EMI issues are just going to become more of a problem with the higher frequencies with Bluetooth, Wi-Fi and now 5G devices,” explains Cambrelin.  “That means EMI filters will have to handle wider frequency ranges while allowing the appropriate signals to pass through,” says Cambrelin.  “This also helps OEMs meet regulatory standards that exist in most countries that limit the amount of noise that can be emitted.”
For more information, contact Johanson Dielectrics at (805) 389-1166, visit web site: johansondielectrics.com/emi or e-mail: emi@johansondielectrics.com.  The company is located at 4001 Calle Tecate, Camarillo, CA 93012.
May 17, 2021 -
Shifting Demand for Multi-Layer Ceramic Capacitors Creates a Critical Supply Shortfall for Industrial and Military Needs
Nov 02, 2020 -
Jun 21, 2019 -
Integrated Passive Components (IPCs) Simplify Signal Conditioning in Package that is 20% the Size
Feb 21, 2019 -
Filtering out Common Mode Noise in Congested Environments with Monolithic EMI filters
Nov 08, 2024 -
ViTrox Strengthens Its Mexico Presence with New Demo Room and Strategic Workforce Expansion
Nov 04, 2024 -
Altus Sees Growing Interest for Laser Depanelling Solutions
Nov 04, 2024 -
StenTech Wins Third Award for Award for Innovative StenTech BluPrint™ PVD Surface Treatment
Nov 04, 2024 -
ViTrox Americas Doubles Capacity at Demo Center in Hutto, Texas
Nov 04, 2024 -
2024 Charles Hutchins Educational Grant Winner Announced
Nov 04, 2024 -
Europlacer Wins Service Excellence Awards for 11th Consecutive Year in Placement and Printing Categories
Nov 04, 2024 -
Nordson Test & Inspection's New SpinSAM™ AMI System Wins Prestigious Global Technology Award
Nov 04, 2024 -
Nordson Electronics Solutions wins Global Technology award for the ASYMTEK Select Coat SL-1040 Conformal Coating System
Nov 04, 2024 -
SMTA Austin Expo & Tech Forum Returns February 6, 2025
Nov 04, 2024 -
Austin American Technology Highlights Cleaning Performance, Technology & Reliability at SMTA Tampa Bay and Space Coast Expos
Advanced EMI Filters Keep Brush DC Motors “Low Cost” news release has been viewed 704 times
Fluid Dispensing Aerospace
