  • Eelink launches the ultra-small temperature tracker BTT01 for cold chain
Aug 21, 2019
 Eelink Communication Technology Limited released the latest GPS tracking devices BTT01, a high accuracy temperature tracker,meanwhile EElink released the latest software APP Keelin-Beacon, in order to meet more customer's needs.
The chief engineer from Eelink communicarion technology limited said:
"Temperature tracker BTT01 is the crystallization of our company's wisdom. Its biggest feature is the ability to detect the temperature in indoor and closed environment in real time. The main application scenarios are cold chain transportation, pharmaceutical transportation, food safety and so on."
It is worth said that the BTT01 is very small and lightweight, weighing only 27g. It is currently the smallest temperature tracker. Due to its small size and light weight, which avoids the installation too complicated, even you can install the BTT01 anywhere you want a monitor temperature.
According to official reports from Eelink communicarion technology limited, they will continue to broaden the scope of application of BTT01. General Manager cheng said: "Although BTT01 is positioned to detect temperature, with the continuous customization of functions, this will be a new multi-function locator, including real-time positioning, fence alert, temperature alarm etc."
temperature tracker btt01
Temperature tracker BTT01 Features
1. Equipped with high accuracy temperature sensor
It is very accurate that we have gain temperature information that device collected,and BTT01 have Wide monitoring temperature range -40°C to 125°C.
2.IP67 Waterproof&Dustproof level
3.4 days local data cache in default mode
4.small and compact design for easy to use
5. Strong long standby performance, no need to charge the battery within 3-5 years
6.Real-time data converting, storing and uploading
7. Can be used with Eelink's self-developed temperature tracker app
Keelin-Beacon supports IOS and Android
More product details
The function of BTT01
1. Support local data caching. We can cache four days of temperature data and other related information, which makes it easier for you to retrieve data and analyze data to achieve your goals. Usually BTT01 save one data package every 5 minutes, and we can quackily view the real-time temperature information
2. Long standby function. The temperature monitor device consumes low power and has strong stability. When using it, we will not charge the battery within 3 to 5 years, which greatly saves the company's manpower and helps companies managed easier.
3. Support working with STF2 devices. One STF2 can work with 24 Beacons
The parameter of products
Waterproof Level:IP67
Case material:PC
Case color:Blue
Voltage:3.0V
Standby Current:5uA-16uA
Peak Current:10mA-45mA
Dimension:66.5(L) x56(W)x6.7(H) mm
Battery type:Li-MnO2, Lithium manganese battery
Battery Capacity:1350mah
Wireless Technology:BLE Bluetooth low energy 5.0 chipset nRF52840
Transmission distance:Max 500m in open space
Broadcast power:8db
Average Current:25uA
Accessory:3M adhesive
Sampling Period:According to customer’s need
Temperature sensor accuracy:±0.5 °C (0°C to 65°C) ±1.0°C (-40°C to 125°C)
Working temperature:-20°C to﹢60°C
Storage temperature:﹣30°C to﹢80°C
LED/Button:Blue LED/Power on; Red LED/Power off
Written at the end:
In the future, Eelink will develop more and more products to meet the needs of customers. BTT01 has received many orders from customers around the world. This means that they recognize our products, which is something to be proud of.
In particular, the Keelin-BEACON APP developed by our software team will help customers to the maximum extent and is currently free to open. more information about EElink
About Eelink Communication Technology Limited
Founded in 2004, Shenzhen Eelink Communication Technology Limited, is an experienced and highly acclaimed company to produce and develop terminal products. They are the brand GPS tracking device manufacturers with world-class hardware and software solutions. Their innovative products and solutions are developed with best industry standards to suit local as well as international markets.
They are committed to producing the best GPS tracker for the world's customers.
They are not only equipment manufacturers, but also a service provider that offers a full range of positioning solutions.
The tracking platform and software APP they developed have become more popular for customers.
EElink  can also customize the function and provide OEM services to meet customer's needs.
website: https://www.eelinktracker.com/
May 03, 2020 -
Eelink developed the most competitive temperature monitoring solution remotely in 2020
Sep 17, 2019 -
Eelink Introduces the latest 4G LTE GPS Tracker TK419.
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Eelink launches the ultra-small temperature tracker BTT01 for cold chain news release has been viewed 780 times
