Level Control
May 31, 2021
Level Switch
The level switch can be electronic or mechanical, it serves only one purpose, which is to give us an alert if it detects the presence of the product. We can control the process in different ways. A continuous application has a transmitter sending online information to the control system. In a simple process, we might use a level switch to take action if we have 50 or 100 percent of the level.
A level switch signals the system whether the level of the measured substance is within expected parameters or not. If not, then the system will open a valve, start a pump, or take some other action to modify the level.
We can use a level switch as an extra layer of protection for sensitive equipment. If the level transmitter we are using as the first line of measurement fails, and the product goes beyond its proper level, then the level switch will alert the system.
Unscheduled problems can come upon any of your field devices, or even worst, the device can be measuring incorrectly and lead to an overfill in your tank. You need to have a plan B to avoid an overfill or any other possible problem, and level switches excel in this kind of application. In fact, it is used most of the time to protect other equipment.
There is a total of three types of level switch. The first type of level switch is the vibrating switch where it works based on the principle of tuning fork. Two prongs vibrating at their neutral frequency. When the product covers the prongs, the frequency drops. The device sends an alert of this change.
The second type of level switch is capacitance level switch where the same principle as continuous level measurement devices are used. The probe and tank walls act as the capacitor plates and the product as the dielectric. If the level reaches the sensor, then the capacitance changes and the sensor send its signal.
The last type of level switch is the float switch. The float switch is a mechanical level sensor for liquids and uses buoyancy to work. When the product reaches the float, the sensor alerts the system to stop the flow.
While the level transmitter is working without problems, the level switch will be there ready to take over control of the situation, avoiding an accident or loss of raw material. Furthermore, it adds another on/off control. The level switch can be a cheap and simple solution for your application.
Level Switch is available through Quick Time Engineering Inc.
Jun 04, 2021 -
Vibration Monitoring
Jun 04, 2021 -
Valves, Fittings & Tubbing
Jun 03, 2021 -
Valve Controllers
Jun 03, 2021 -
Turbine Parts
Jun 03, 2021 -
Transmitter
Jun 03, 2021 -
Transducer
Jun 03, 2021 -
Thermostat
Jun 03, 2021 -
Thermocouple
Jun 02, 2021 -
Solenoid Valve
Jun 02, 2021 -
Soft Starter
Jul 02, 2024 -
Totech Canada N/A Inc celebrates 5 Year as Official Distributor for TOTECH GLOBAL North America
Jul 01, 2024 -
XDry Dry Cabinets Hires Wilson Industries as Representative for New York
Jul 01, 2024 -
EVS International Welcomes Circuit Assembly Products SE as New Representative for Southern States
Jul 01, 2024 -
Prey by Detech Partners with Accurex Solutions to Expand Presence in India
Jul 01, 2024 -
PEMTRON to Showcase Advanced Inspection Systems at ASPS in Korea
Jul 01, 2024 -
iNEMI Announces Member Recognition Awards for 2024
Jul 01, 2024 -
IPC White Paper Emphasizes the Critical Importance of 'Design for Excellence' Throughout the Full Ecosystem of Electronics Design
Jul 01, 2024 -
ZESTRON Welcomes Daniel Chacon to the LATAM Sales Team
Jul 01, 2024 -
TAGARNO Welcomes Mark Sullivan as New Sales Representative for the American Market
Jul 01, 2024 -
ViTrox Americas Opens New State-of-the-Art Demo Lab in Hutto, Texas
Level Control news release has been viewed 552 times
