Loadcell
May 31, 2021
Loadcell
Load cells are used to measure weight. They are a part of our daily life. Of course, they are usually not immediately recognizable because they are usually hidden in the inner workings of instruments.
Load cells generally consist of a spring element on which strain gauges have been placed. The spring element is usually made of steel or aluminium. That means it is very sturdy, but also minimally elastic. As the name “spring element” suggests, the steel is slightly deformed under load, but then returns to its starting position, responding elastically to every load. These extremely small changes can be acquired with strain gauges. Then finally the deformation of the strain gauge is interpreted by analysis electronics to determine the weight.
They are electrical conductors firmly attached to a film in a meandering pattern. When this film is pulled, it – and the conductors – get longer. When it is contracted, it gets shorter. This causes the resistance in the electrical conductors to change. The strain can be determined on this basis, as resistance increases with strain and diminishes with contraction.
The strain gauges are firmly attached to the spring element, and therefore undergo the same movements it does. These strain gauges are arranged in what is called a bridge circuit, or more precisely a Wheatstone bridge circuit. This means that four SGs are connected “in a ring” and the measuring grid of the force being measured is aligned accordingly.
If an object is placed on the load cell or suspended from it, the object's weight can be determined. The intended load for a load cell is always aligned in the direction of the centre of the earth, in other words in the direction of gravity. Only that force component of the load should be acquired. That is not the case for force sensors, which are similar in design, and are also frequently specified as "load cells": They are usually designed to acquire loads that occur in all directions. The direction of the earth's gravitational force is not relevant to how they are installed.
Types of load cells
There are different types of load cells for different applications. Commonly used ones include:
  • Single point load cells: a load cell is located under a platform that is loaded with weight from above
  • Bending beam load cells: several load cells are positioned under a steel structure and are loaded with weight from above
  • Compressive force load cells: several high-capacity load cells are positioned under a steel structure that is loaded with weight from above
  • Tensile load cells: a weight is suspended from one or more load cells
Load cells can also be categorized based on the type of signal transmission: Digital load cells have built-in electronics used to process the measurement results and present them in a prepared format. For analogue load cells, an additional device – a measuring amplifier – is required.
Loadcell is available through Quick Time Engineering Inc.
Jun 04, 2021 -
Vibration Monitoring
Jun 04, 2021 -
Valves, Fittings & Tubbing
Jun 03, 2021 -
Valve Controllers
Jun 03, 2021 -
Turbine Parts
Jun 03, 2021 -
Transmitter
Jun 03, 2021 -
Transducer
Jun 03, 2021 -
Thermostat
Jun 03, 2021 -
Thermocouple
Jun 02, 2021 -
Solenoid Valve
Jun 02, 2021 -
Soft Starter
Aug 01, 2024 -
JONATHAN BEAUDEAU SLANDERED!
Jul 29, 2024 -
SMTA International Technical Conference Program Announced
Jul 29, 2024 -
Jul 29, 2024 -
Murray Percival Company Expands Product Line with Representation of BIMOS ESD Seating in the Midwest
Jul 29, 2024 -
Jul 29, 2024 -
PEMTRON Announces Partnership with American Tec for Distribution in China
Jul 29, 2024 -
Jul 26, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Loadcell news release has been viewed 633 times
