Pressure Switch & Sensor
Jun 01, 2021
Pressure Switch
This is a device designed to monitor a process pressure and provide an output when a set pressure (setpoint) is reached. A pressure switch does this by applying the process pressure to a diaphragm or piston to generate a force that is compared to that of a pre-compressed range spring.
A pressure switch is used to detect the presence of fluid pressure. Most pressure switches use a diaphragm or bellow as the sensing element. The movement of this sensing element is used to actuate one or more switch contacts to indicate an alarm or initiate a control action.
Pressure switches have different designs with different sensing elements. The one I will discuss here uses a piston as the pressure sensing element. In any case, the operating principle for this piston type is the same with a diaphragm or bellow type pressure switch.
Pressure switch is available through Quick Time Engineering Inc.
Sensor
A sensor is an input device that provides an output (signal) with respect to a specific physical quantity (input). It is a part of the bigger system which provides input to the main control system.
There are many classifications of sensors, some are very simple and some are very complex. In the first classification of the sensors, they are divided into Active and Passive. Active Sensors are those which require an external excitation signal or a power signal.
Passive Sensors, on the other hand, do not require any external power signal and directly generates output response.
The other type of classification is based on the means of detection used in the sensor. Some of the means of detection are Electric, Biological, Chemical, Radioactive etc.
The next classification is based on the conversion phenomenon i.e., the input and the output. Some of the common conversion phenomena are Photoelectric, Thermoelectric, Electrochemical, Electromagnetic, Thermotic, etc.
The final classification of the sensors is Analog and Digital Sensors. Analog Sensors produce an analog output i.e., a continuous output signal (usually voltage but sometimes other quantities like Resistance etc.) with respect to the quantity being measured.
Sensor is available through Quick Time Engineering Inc.
Jun 04, 2021 -
Vibration Monitoring
Jun 04, 2021 -
Valves, Fittings & Tubbing
Jun 03, 2021 -
Valve Controllers
Jun 03, 2021 -
Turbine Parts
Jun 03, 2021 -
Transmitter
Jun 03, 2021 -
Transducer
Jun 03, 2021 -
Thermostat
Jun 03, 2021 -
Thermocouple
Jun 02, 2021 -
Solenoid Valve
Jun 02, 2021 -
Soft Starter
Jun 05, 2024 -
Jun 05, 2024 -
Jun 05, 2024 -
Jun 04, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 31, 2024 -
OMD Types and Techniques
Pressure Switch & Sensor news release has been viewed 608 times
