Safety Barrier and Isolator
Jun 02, 2021
Programming Cable
Programming cables are the hardware connection for configuration & communication with all respective devices. Programming cables connect to either USB or PC Parallel ports and use fly-ware connectors to the target board.
Programming cable is available through Quick Time Engineering Inc.
Contact Blocks
A contact block is an electrical circuit connector that is used to turn on (make) or turn off (break) an electrical circuit. Contact blocks are commonly found connected to switches, relays and circuit breakers, once these devices are active the contact block allows current to flow and complete a circuit.
Contact blocks are usually designed as an accessory to fit a specific device, therefore matching the correct contact block and device are essential. The contact blocks are available with a wide range of contact configurations that allow the main device to change a circuit in many different ways. Typical contact configurations available are:
  • 1NO (One normally open contact)
  • 1NC (One normally closed contact)
  • 1NO/1NC (One normally open and one normally closed)
  • 2NO (Two normally open contact)
  • 2NC (Two normally closed contact)
  • 2NO/2NC (Two normally open and two normally closed)
Contact block is available through Quick Time Engineering Inc.
Jun 04, 2021 -
Vibration Monitoring
Jun 04, 2021 -
Valves, Fittings & Tubbing
Jun 03, 2021 -
Valve Controllers
Jun 03, 2021 -
Turbine Parts
Jun 03, 2021 -
Transmitter
Jun 03, 2021 -
Transducer
Jun 03, 2021 -
Thermostat
Jun 03, 2021 -
Thermocouple
Jun 02, 2021 -
Solenoid Valve
Jun 02, 2021 -
Soft Starter
Aug 28, 2024 -
Mencom to Exhibit at More Than MFG Expo 2024
Aug 28, 2024 -
Can Laser Technology Save Your Catheter Manufacturing?
Aug 26, 2024 -
Aug 26, 2024 -
Aug 26, 2024 -
Aug 26, 2024 -
Aug 26, 2024 -
Aug 26, 2024 -
Aug 26, 2024 -
Aug 26, 2024 -
Safety Barrier and Isolator news release has been viewed 519 times
