Smoke Detector
Jun 02, 2021
Smoke Detector
A smoke detector is an electronic fire-protection device that automatically senses the presence of smoke, as a key indicator of fire, and sounds a warning to building occupants. Commercial and industrial smoke detectors issue a signal to a fire alarm control panel as part of a building’s central fire alarm system. By law, all workplaces must have a smoke detection system. Household smoke detectors, smoke alarms, issue an audible and/or visual alarm locally from the detector itself. They can be battery-powered single units or several interlinked hardwired (mains-powered) devices backed up by batteries. The latter must be installed in all new buildings and after major refurbishments.
There are two types of smoke detector in the market. Ionization smoke alarms are generally more responsive to flaming fires. Ionization-type smoke alarms have a small amount of radioactive material between two electrically charged plates, which ionizes the air and causes current to flow between the plates. When smoke enters the chamber, it disrupts the flow of ions, thus reducing the flow of current and activating the alarm. Photoelectric smoke alarms are generally more responsive to fires that begin with a long period of smouldering (called “smouldering fires”). Photoelectric-type alarms aim a light source into a sensing chamber at an angle away from the sensor. Smoke enters the chamber, reflecting light onto the light sensor; triggering the alarm.
For each type of smoke alarm, the advantage it provides may be critical to life safety in some fire situations. Home fatal fires, day or night, include a large number of smouldering fires and a large number of flaming fires. You cannot predict the type of fire you may have in your home or when it will occur. Any smoke alarm technology, to be acceptable, must perform acceptably for both types of fires in order to provide early warning of fire at all times of the day or night and whether you are asleep or awake. For best protection, it is recommended both (ionization and photoelectric) technologies be used in homes. In addition to individual ionization and photoelectric alarms, combination alarms that include both technologies in a single device are available.
Smoke Detector is available through Quick Time Engineering Inc.
Jun 04, 2021 -
Vibration Monitoring
Jun 04, 2021 -
Valves, Fittings & Tubbing
Jun 03, 2021 -
Valve Controllers
Jun 03, 2021 -
Turbine Parts
Jun 03, 2021 -
Transmitter
Jun 03, 2021 -
Transducer
Jun 03, 2021 -
Thermostat
Jun 03, 2021 -
Thermocouple
Jun 02, 2021 -
Solenoid Valve
Jun 02, 2021 -
Soft Starter
Sep 14, 2024 -
DELKIN DEVICES CE02TFNHK-FD000-D
Sep 14, 2024 -
HONEYWELL 8C-TDOD51 Digital input Module
Sep 14, 2024 -
SIEMENS 7TS4022-1/BB
Sep 14, 2024 -
HONEYWELL FS-USI-0001 UNIVERSAL SAFETYINTERFACE MODULE
Sep 14, 2024 -
ABB 3BHB003387R0101 5SXE 05-0151 5SHX 08F4502
Sep 14, 2024 -
KETOP T50 R01 VX/69908/14 Discrete Output Module Cable 5m
Sep 14, 2024 -
ABB HIEE401481R0001 UAC326 AE01
Sep 14, 2024 -
GE TGT-AIOV-8-0 Analog l/0 Module
Sep 14, 2024 -
GE IS220PDOAH1B Discrete Output Module
Sep 14, 2024 -
ALSTOM 8933-0000 Regelsatz
Smoke Detector news release has been viewed 680 times
